THE_BLUE's avatar
THE_BLUE
May 28, 2023
Secure connection failed - pool 443
i have 2 vs of port 443 and 80 , and pool of 443 and 80 too . from server itself, the website works fine with both ports . But from waf if i enable the vs with pool 443 i receive " secure connection faild" and if i replace it with pool 80 it's work fine.
What is the issue with 443? i have enable the ssl profile from both side . how to troubleshoot this iisue?
  • Hi THE_BLUE,
    If server side ssl, server-ssl profile is required. There may be a issue with the cipher configuration.
    Can you try sending a curl request to the server from the F5 command line?
    curl -kv "https://serverip" -H "Host: example.com"
    If the command returns an SSL error, there may be SNI problem.
    https://support.f5.com/csp/article/K41600007
    • THE_BLUE's avatar
      THE_BLUE
      with port 443 i have tried with server ssl and without and i get the same result .
      i will try now to use the mentiond command .
    • THE_BLUE's avatar
      THE_BLUE
      * TLSv1.2 (OUT), TLS header, Certificate Status (22):
      * TLSv1.2 (OUT), TLS handshake, Client hello (1):
      * Unknown SSL protocol error in connection to serverip:443
      * Closing connection 0
      curl: (35) Unknown SSL protocol error in connection to serverip:443
