Letau's avatar
Letau
Jun 29, 2022
Solved
Response port masking
Our F5 is forwarding traffic to IIS web servers on non-standard ports (such as 8081). The application on the web server will send traffic back to http://app.blah.com:8081.
How do I get the F5 to remove the port number from the response that is sent back to the client - in other words replace any instance of http://app.blah.com:8081 with http://app.blah.com in the response?
This is a similar question to https://community.f5.com/t5/technical-forum/remove-port-from-http-response/td-p/109510 however it is not detailed as to what was done, i woould highly appreciate your feedback
  • Hi
    I actully found the solution to be under the Virtual Server Configuration -> Advanced -> Check "Port Translation"
  • That post, and the one it links to in more complete form, provides the answer to your question. Is there something else you're looking for in addition?
  • Letau's avatar
    Letau
    Hi
