Vladimir_Akhmarov's avatar
Dec 08, 2022
Solved
No matches under XML_CONTENT_BASED_ROUTING
Hello!
I have a requirement to match and log selected XML content under APM enabled VS
I tried to follow https://techdocs.f5.com/en-us/bigip-15-0-0/big-ip-local-traffic-manager-implementations/routing-based-on-xml-content.html#GUID-CB96E40C-6AA4-4B0F-A8A4-3A131BC10BB1
Here is a XML:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:t="http://schemas.microsoft.com/exchange/services/2006/types">
    <soap:Header>
        <t:RequestServerVersion Version="Exchange2007_SP1"/>
    </soap:Header>
    <soap:Body>
        <m:GetFolder xmlns:m="http://schemas.microsoft.com/exchange/services/2006/messages" xmlns:t="http://schemas.microsoft.com/exchange/services/2006/types">
            <m:FolderShape>
                <t:BaseShape>IdOnly</t:BaseShape>
            </m:FolderShape>
            <m:FolderIds>
                <t:DistinguishedFolderId Id="root"></t:DistinguishedFolderId>
            </m:FolderIds>
        </m:GetFolder>
    </soap:Body>
</soap:Envelope>
Here is a XML profile:
ltm profile xml /Common/EWS_xml {
    app-service none
    defaults-from xml
    namespace-mappings {
            mapping-namespace http://schemas.microsoft.com/exchange/services/2006/messages
            mapping-prefix m
    xpath-queries { //m:getfolder/* }
Here is an iRule:
when XML_CONTENT_BASED_ROUTING priority 500 {
    for {set i 0} { $i < $XML_count } {incr i} {
        if {$static::iteco_exch_debug == 1} {
            log local1.debug "APM: 0149FFFF:F: [ACCESS::session data get "session.user.sessionid"]: $XML_queries($i) = $XML_values($i)"
Unfortunately I miss something and there are no logs nor iRule event XML_CONTENT_BASED_ROUTING matches
Can you help me to understand what is wrong in my configuration?
  • Kai_Wilke's avatar
    Kai_Wilke
    Dec 08, 2022
    Hi akhmarov,
    just wanted to get sure... 😉
    Try to format your xpath-query case-sensitive... 😉
    //m:GetFolder/*
    Cheers, Kai
  • Hi akhmarov,
    I'm afraid to ask, but did you assigned the XML profile to your Virtual Server?
    Cheers, Kai
    • Yes, of course 🙂
      ltm virtual /Common/EWS_vs {
          profiles {
              /Common/EWS_xml {
                  context all
        Kai_Wilke
        Icon for MVP rankMVP
        Hi akhmarov,
        //m:GetFolder/*
        Cheers, Kai
