29-Jan-2020 11:34
Hi Team ,
I have below Irule which currently works for specific single source IP 10.10.10.1 ...I would like to add more IP using Datagroup , Could you please help me modify this irule .
I tried but I got error "variable reference required proceeding $"
Note : We have route domain configured and VIP is configured in route domain %70 .
Thanks in Advance 🙂
if {
([IP::client_addr] contains "10.10.10.1%70") && ([string tolower [HTTP::uri]] contains "/cklauncher/")
drop
elseif { [string tolower [HTTP::path]] equals "/" && ( [IP::addr [IP::client_addr] equals 10.10.10.1%70]) } {
# redirect the request
log local0. "issuing redirect request to [HTTP::host][HTTP::uri] from [IP::client_addr]"
HTTP::redirect https://[getfield [HTTP::host] ":" 1]/ckpartner/
Solved! Go to Solution.
29-Jan-2020 13:21
Any chances to same client IP address appears on different route domains on this iRule? Because I think IP data group won't consider route domains on validation, but I'm not 100% sure. This way, I think working on data group type ip route domain number wold be noise optional.
ltm data-group internal dg_my_ip_list {
records {
10.10.10.1%70/32 { }
type ip
if { [class match [IP::client_addr] equals dg_my_ip_list] } {
if { [string tolower [HTTP::path]] equals "/cklauncher/" } {
drop
} elseif { [HTTP::path] equals "/" } {
I hope it helps.
Best regards.
29-Jan-2020 13:21
records {
type ip
drop
I hope it helps.
Best regards.
10-Apr-2020 07:17
Hi Cjunior,
I need help here .
With Datagroup I want to block access to both the uri's /cklauncher/ and /ckpartener/ and anything else should be accessible .
10-Apr-2020 08:49
Hello,
Changing this part, will that work for you?
if { [string tolower [HTTP::path]] equals "/cklauncher/" or [string tolower [HTTP::path]] equals "/ckpartener/" } {
drop
Regards
13-Apr-2020
02:44
- last edited on
24-Mar-2022
01:11
by
li-migration
I will try this , Thank you
records {
type ip
drop
