Stefan_Engel's avatar
Jun 21, 2021
Solved
Is save sys config required for iControl/REST changes?
Hi Community,
I'm running an Ansible playbook using a variation of Ansible Modules/REST calls to make changes.
When is it required to do a save sys config to apply running to system config?
  • GUI --> no
  • any type tmsh config --> yes
  • Ansible modules / REST --> ?
Thanks in advance
  • Hi Stefan,
    Yes, it's indeed required if you want to save the running config to stored config. (iControl is more closely linked to TMSH than the GUI) Same with TMSH though; you don't need to save the config in order to make it active.
    See here for some further details on it:
    https://cdn.f5.com/websites/devcentral.f5.com/downloads/icontrol-rest-api-user-guide-15-1-0.pdf (page 53)
    https://support.f5.com/csp/article/K13225405 (search for "save")
    https://clouddocs.f5.com/training/fas-ansible-workshop-101/1.7-save-running-config.html
    Hope this helps.
  • Hi Stefan,
    Hope this helps.
