Tony_Bourke_935
Sep 09, 2010iRules HTTP_RESPONSE based on Pool?
Is there a way to do switch or if statements based on the pool the response came from?
For example:
I'm dividing up traffic into two pools based on the URI. Pool "http" and pool "gopher".
I need to rewrite http:// to https:// if the response was sent to pool "http", and rewrite http:// to gopher:// if it came from pool "gopher".
- Chris_Miller
Altostratus
Here's the HTTP_RESPONSE wiki which also contains available commands:
http://devcentral.f5.com/wiki/default.aspx/iRules/HTTP_RESPONSE.html
Do the servers in your HTTP and Gopher pools share the same IPs? If they don't, you could look at IP::server_addr and rewrite based on that. - Tony_Bourke_935
Hi Chris,
Yeah, I was hoping to avoid having to define the pool members in the iRule itself, then having two separate places to worry about in terms of keeping pool members updated. If I add a server into a pool, I'd have to remember to add the server into the pool list variable in the iRule.
The HTTP_REPONSE wiki page doesn't seem to have any way to define an action to be taken depending on the pool that the HTTP_REQUEST was sent to. - Chris_Miller
Altostratus
I suppose you could set a variable in the LB_SELECTED event that you check for in your response event... - L4L7_53191
Hi Tony: would it be possible to simply set a variable in your HTTP_REQUEST event that you reference on HTTP_RESPONSE? For example, you've already made a decision to send some traffic to one pool or the other based on uri, so you should be able to do this.
Here's some non-tested, free form code as an example.when HTTP_REQUEST { if {HTTP::uri equals '/foo'} { set selected 'gopher' pool gopher } else { set selected 'http' pool http } } when HTTP_RESPONSE { log local0. "This response is coming from pool $selected..." }
I'm sure I've got a fat-finger or two in here but hopefully it'll give you an idea of what I am thinking here.
-Matt - L4L7_53191
By the way you could also use LB::server in the request event to set the pool name of the node, if I recall...so it would look something like:set selected [LB::server pool]
...but the first option may make more sense.
-Matt
