iRule to modify http response
Hello all,
Seeking some assistance with modifying a http response from a server back to a client.
Senario is as follows (All web traffic)
- VS_A answers on 443 and sends to pool members on 9999
- VS_B answers on 888 and sends to same pool members on 7777
- When browsing to VS_B, there is a function that is on the site that responds with the public url of VS_A (ex https://www.acme.com:9999) instead of https://www.acme.com and hence causes a timeout because the clients are not able to access that port directly.
I am seeking to remove the port but keep all uri information.
Additionaly
Do I need any specific settings for the VS in order for this to work?
I have http-wxff profile I have sslclient profile I have sslserver profile
am I missing anything obvious?
Update....... I am trying below
I am attempting to modify a server response back to the client. I am attempting to remove the port from the url the client receives while still perserving the case and uri information.
When attempting this I notice no 302 response (Using firefox) and no location information. Seeking help to get this sorted.
when HTTP_REQUEST { Disable the stream filter for requests STREAM::disable
Remove this header to prevent server from compression response
HTTP::header remove Accept-Encoding
} when HTTP_RESPONSE { set internal_host "xxx.yyy.com" set external_host "boy.girl.com" Rewrite the Location header for redirects if { [HTTP::header exists Location] }{ HTTP::header replace Location [string map "$internal_host $external_host" [HTTP::header Location]] }
Rewrite the response content using a stream profile if it is text
if { [HTTP::header Content-Type] contains "text" } {
Set the stream expression with the find/replace strings
STREAM::expression "@$internal_host@$external_host@"
Enable the stream filter
STREAM::enable
- JG
Cumulonimbus
"there is a function that is on the site that responds with the public url of VS_AWas this in the form of an HTTP redirect?
- Pedro_HaoaRet. Employee
Try this iRule:
when HTTP_RESPONSE { if { [HTTP::status] equals "302" && [HTTP::header Location] contains ":9999/" } { HTTP::header replace Location [string map {":9999/" ""} [HTTP::header Location]] } }
I hope it helps.
Cheers!
- RobinsonJA_2717
There is an option that when selection responds with the location on another url on a specific port.
- JG
Cumulonimbus
If it is an HTTP redirect, you can edit your HTTP profile and select "All" for "Redirect Rewrite".
- JG
Cumulonimbus
Try this one then:
when HTTP_RESPONSE { if { [HTTP::header exists "Location"] } { log local0. "Original Location: [HTTP::header Location]" set new_location [string map {"www.acme.com:9999" "www.acme.com:888"} [HTTP::header value Location]] HTTP::header replace Location $new_location } } - stan_piron
Cumulonimbus
You can try to use rewrite profile instead of irule.
Create a rewrite profile type translation.
Create a rule in this profile with parameters:
- direction : response
- client URL : https://www.acme.com/
- server URL : https://www.acme.com:9999/
Assign this profile to the VS_B
- RobinsonJA_2717
Able to resolve using the original iRule. Had a tired brain in messing with wrong virtual servers. Thanks all for you assistance.
