17-Nov-2022 02:46
I'm trying write an iRule for an upcoming migration where we have multiple sites (MS Sharepoint) using the same host with different URI's. Some I want to just forward to a specific pool, while the 'rest' to be redirected to a new page. The 'rest' is basically everything starting with intranet, except some of the specific URI
when HTTP_REQUEST
{ if
{ ([HTTP::host] starts_with "intranet") && ([HTTP::uri] equals "/AAA/") } { pool intranet_pool
} elseif
{ ([HTTP::host] starts_with "intranet") && ([HTTP::uri] equals "/BBB/") } { pool intranet_pool
} elseif
{ [HTTP::host] starts_with "intranet" } { HTTP::redirect https://intranet.new
I'm facing 2 issues:
Do I need to exit the iRule somehow after I got the first match? Or how do I stop further processing?
I've tried the same with LTM Policy, but getting same results.
Appreciate your feedback. Thanks.
Solved! Go to Solution.
17-Nov-2022 05:06
Hi Stefan_Engel,
In your code, a redirect loop occurs because the redirected page always starts with "intranet". Can you try this iRule?
if { [HTTP::host] starts_with "intranet" && [HTTP::uri] equals "/AAA/" } {
pool intranet_pool
return
} elseif { [HTTP::host] starts_with "intranet" && [HTTP::uri] equals "/BBB/" } {
pool intranet_pool
return
} elseif { [HTTP::host] starts_with "intranet" && [HTTP::uri] ne "/" } {
return
If the uri is not "/", it will redirect.
If the uri is "/", it will not redirect, traffic will be forwarded to the default pool.
If there is no character after the hostname in url, the uri is always "/".
17-Nov-2022 05:06
Hi Stefan_Engel,
pool intranet_pool
return
pool intranet_pool
return
return
17-Nov-2022 05:13
I would add some log statements to see exactly what you're getting. It could simply be a string case issue.
On the redirects, your last line is causing this. You're basically saying if the host starts with "intranet", redirect to "intranet.new". But if the same iRule processes intranet.new, then that too will start with "intranet".
log local0. "Incoming: [HTTP::host][HTTP::uri]"
if { ( [HTTP::host] starts_with "intranet" ) && ( [HTTP::uri] equals "/AAA/" ) } {
log local0. "Catch /AAA/ - Sending to intranet_pool"
pool intranet_pool
} elseif { ( [HTTP::host] starts_with "intranet" ) && ( [HTTP::uri] equals "/BBB/" ) } {
log local0. "Catch /BBB/ - Sending to intranet_pool"
pool intranet_pool
} elseif { ( [HTTP::host] starts_with "intranet" ) && ( [HTTP::host] ne "intranet.net" ) } {
18-Nov-2022 00:05
Thank you both for the response. I've added logging which helped and the ne "/" solved the loop on redirects.
