Technical Forum
iRule and multiple switch-statements
shakalakka
Altostratus
Altostratus
So we need to filter based on both URIs and host-headers AND the source-IPs. I have tried using two switch-statements, with the same action for both if the client-IP-range matches - the first one works, but the second one doesnt seem to be evaluated. Any tips?
iRule:
   set RESPONSE "<html><title>404 - NOT FOUND</title><body>404 - not found</body></html>"
   switch -glob [string tolower [HTTP::uri]] {
      "/someuri" -
      "/someuri/*"  {
         if { [matchclass [IP::client_addr] equals dg_blockthesehosts ] } {
            HTTP::respond 404 -version auto content $RESPONSE noserver "Content-Type" "text/html;charset=utf-8"
            TCP::close
            event disable
            return
   switch -glob [string tolower [HTTP::host]] {
      "Host1.host.com" -
      "Host2.host.com" {
            TCP::close
            event disable
            return
7 REPLIES 7
Kevin_Stewart
F5 Employee
F5 Employee
Don't know if you're obfuscating for this post, but you have [string tolower [HTTP::host]] as the condition, but trying to evaluate mixed case strings (ex. Host1.host.com).
shakalakka
Altostratus
Altostratus
Yes, sorry, this is example-names, and should read host1.host1.com.
But is something missing to open a second switch-statement?
Kevin_Stewart
F5 Employee
F5 Employee
The second switch will indeed not fire if there's a URI match, since that is doing an 'event disable'. So the logic presumes that the request does not match the URI in order to do a match on the host.
For giggles, try adding some logging and see what falls out:
   log local0. "host: [string tolower [HTTP::host]]"
      "/someuri" -
      "/someuri/*"  {
         log local0. "match URI: [string tolower [HTTP::uri]]"
            TCP::close
            event disable
            return
   switch [string tolower [HTTP::host]] {
      "host1.host.com" -
      "host2.host.com" {
         log local0. "match host: [string tolower [HTTP::host]]"
            TCP::close
            event disable
            return
I will try. That is correct, the URI and host-header matching will not happen on the same site, so the logic is something like this:
If you are a source-IP in dg_blockthesehosts:
Give a 404 if you try to access /someuri/*
OR:
if you try to access host1.host.com or host2.host.com.
They wont try to access host1.host.com/someuri.
T-Trust
Cirrus
Cirrus
Hi shakalakka,
I hope this iRules will help you,
set httphost [string tolower [HTTP::host]]
set httpuri [string tolower [HTTP::uri]]
if { ($httphost contains “x1”) && ($httpuri contains “y1”) } {
pool pool1
} elseif { ($httphost contains “x2”) && ($httpuri contains “y2”) } {
pool pool2
pool pool3
More information >> cloud-ttrust  <<
CA_Valli
MVP
MVP
Hello shakalakka,
I've noticed that you didn't include default condition in your switch blocks, so I'm assuming second block might never be evaluated since code likely breaks at first evaluation.
I'm pretty sure that if you try to swap the two blocks and put HOST check first, it will start working and it will break URI check.
Can you try this ?
      "/someuri" -
      "/someuri/*"  {
            TCP::close
            event disable
            return
      } default {}
      "Host1.host.com" -
      "Host2.host.com" {
            TCP::close
            event disable
            return
