F5Team's avatar
F5Team
Icon for Cirrus rankCirrus
Feb 27, 2023
Iquery connection with translation address
Hi All,
I need some help to understand the iquery connection to translation address . For example
Address : 1.1.1.1
Transalation address 2.2.2.2
F5 will initiate the traffic to 1.1.1.1 or 2.2.2.2 , As my understanding F5 device initiate the traffic to 1.1.1.1 to establish the iquery.
But on the device i could see F5 initiate the traffic to translation address.
is there any document to refer which destination iquery mesh will connect when translation address.
  • Your understanding is correct. This behavior is documented here: https://my.f5.com/manage/s/article/K14707
    Did you run the bigip_add command after configuring the BIG-IP as a server object? That is required for iQuery to behave properly. What version of TMOS are you running?
    • F5Team's avatar
      F5Team
      Version is 14.1.x , I could see the iquery traffic to translation address .
      But when i run the command show gtm iquery ,it connected with actual server address not translate address .
