07-Jul-2020 07:24
Hi All,
We have two customers which are trying to install 14.1.2.6 on a partition prior to upgrade from 14.1.2.5. But the installation fails right away with the following erros in /var/log/liveinstall.log
*** Live install start at 2020/07/06 18:08:23 ***
info: tm_install::BootLoader::BootLoader_mboot_sync_from_old_conf -- Configurations match.
info: Daemon-driven execution indicated by ENV variable.
info: Repository tm_install version/release is 2.12.0.6/4.0
info: System tm_install version/release is 2.12.0.6/4.0
info: Platform id is C117
/dev/sdd: No medium found
sfdisk: cannot open /dev/sdd for reading
info: Basic disk format validation passed.
info: >++++ result:
info: mount: /dev/mapper/vg--db--sda-set.2._usr is already mounted or /mnt/tm_install/30655.GyI1Fy/usr busy
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /usr
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /opt/.sdm/usr
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /opt/.sdm/lib
info: /dev/mapper/vg--db--sda-set.2._usr is already mounted on /opt/.sdm/lib64
info: >----
error: status 8192 returned by command: mount -oro /dev/vg-db-sda/set.2._usr /mnt/tm_install/30655.GyI1Fy/usr 2>/dev/null
info: >++++ result:
info: umount: /mnt/tm_install/30655.GyI1Fy/shared: not mounted
info: >----
error: status 8192 returned by command: umount /mnt/tm_install/30655.GyI1Fy/shared
Terminal error: Could not access configuration source; sda, 2
*** Live install end at 2020/07/06 18:08:27: failed (return code 2) ***
I could not find anything related in the F5 knowledge base articles.
Customer already tried to delete an create a partition again, but this did not solve the issue.
Anyone else facing the same issue? Anyone has a solution?
Regards,
Martijn
07-Jul-2020 07:31
Hi Martijn,
Did they check the ISO against the MD5 hash??
Cheers,
Kees
07-Jul-2020 10:19
Suffering exactly the same problem trying to install 14.1.2.6 on Virtual Edition running 14.1.2.5.
Tried deleting and re-creating the volume, same problem. Checked and MD5 hash is fine, in fact i have been able to install a standalone test instance with 14.1.2.6 (from 14.1.2.5) without any issues.
Tried re-installing 14.1.2.2 which was on the volume orignally, and with that I now get the error "failed (Could not access license source; sda, 1 )"
*** Live install start at 2020/07/07 18:09:08 ***
info: Repository tm_install version/release is 2.12.0.3/6.0
info: Platform id is Z100
error: status 8192 returned by command: mount -oro /dev/vg-db-vda/set.1._usr /mnt/tm_install/30190.WXdfNO/usr 2>/dev/null
info: >++++ result:
info: mount: /dev/mapper/vg--db--vda-set.1._usr is already mounted or /mnt/tm_install/30190.WXdfNO/usr busy
info: /dev/mapper/vg--db--vda-set.1._usr is already mounted on /usr
info: /dev/mapper/vg--db--vda-set.1._usr is already mounted on /opt/.sdm/usr
info: /dev/mapper/vg--db--vda-set.1._usr is already mounted on /opt/.sdm/lib
info: /dev/mapper/vg--db--vda-set.1._usr is already mounted on /opt/.sdm/lib64
info: >----
error: status 8192 returned by command: umount /mnt/tm_install/30190.WXdfNO/shared
info: >++++ result:
info: umount: /mnt/tm_install/30190.WXdfNO/shared: not mounted
info: >----
Terminal error: Could not access license source; sda, 1
*** Live install end at 2020/07/07 18:09:09: failed (return code 2) ***
09-Jul-2020 07:25
Got this from Martijn and it solved it in our F5: https://cdn.f5.com/product/bugtracker/ID915605.html
09-Jul-2020 08:11
Yup i got the same answer, so now have upgraded both my boxes, its related to the iRuleLX component being licensed and activated, means that each upgrade from now on will have to remember to perform the remount command before installing the update, and for safety only do it on the offline / standy unit (not sure what remounting /usr read only could potentially do to the live unit, and don't feel like "testing" it on our production kit!)
04-Aug-2020 09:37
It's fixed in version 15
04-Aug-2020 08:01
Thanks a lot! It's working for me now.
Yves
