wai_98783's avatar
wai_98783
Apr 25, 2012
how to get bigip.config and bigip_base.config from F5 Enterprise Manager directly instead of getting it from ucs archive
hi all,
I am writing a java program trying to get bigip.conf and bigip_base.config from each F5 devices managed by F5 Enterprise Manager. So far i can get to the .ucs, unfortunately this file type cannot open using Zip utility. .ucs file do contain two files after extraction twice.
Is there any API that i can use to get these 2 files directly instead of getting the ucs file?
Thank you for any help.
