Robbie_Wiley_78's avatar
Robbie_Wiley_78
Sep 22, 2014
How do you Import PFX file using iControl with Powershell?
Using 11.4.1, how do I import a pfx file using iControl/Powershell. In the UI, I navigate to System --> File Management --> SSL Certificate List. Click Import, change the "Import Type" drop down to PKCS 12 (IIS), enter a label for my cert in Certificate (ie: testCert), use "Choose File" to navigate to where I've stored the PFX and select the PFX. Enter the password needed by the PFX file (ie: testpassword) and click import.
I see under icontrol there is a ManagementKeyCertificate.pkcs12_import_from_file and ManagementKeyCertificate.pkcs12_import_from_file_v2
v2 is for 11.5 and above. It doesn't work on 11.4. So just ManagementKeyCertificate.pkcs12_import_from_file
I look up the overloads for this and it seems fairly straightforward: void pkcs12_import_from_file(iControl.ManagementKeyCertificateManagementModeType mode, string[] ids, string[] file_names, string[] passwords, bool overwrite)
which I translate to
$icontrol.ManagementKeyCertificate.pkcs12_import_from_file(0,@(,"testCert"),@(,"c:\temp\testCert.pfx"),@("testPassword"),$false)
which blows up with Invalid filename. Filenames may only contain the following characters: [A-Za-z][0-9].-_/"
so I try variations on the filename including setting my location to c:\temp and trying
$icontrol.ManagementKeyCertificate.pkcs12_import_from_file(0,@(,"testCert"),@(,"testCert.pfx"),@("testPassword"),$false)
which gets error:2006D080:BIO routines:BIO_new_file:no such file""
and
$icontrol.ManagementKeyCertificate.pkcs12_import_from_file(0,@(,"testCert"),@(,"/temp/testCert.pfx"),@("testPassword"),$false)
which results in: error:02001002:system library:fopen:No such file or directory""
sooo...... I guess the crux of my problem is: How do I specify where the pfx to import is located? I've seen a couple other questions with this same problem but they don't have answers... so here's my hat in the ring
  • There was mention in one of the posts that indicated that the certificate had to on the F5 device before these commands would work. I have looked for info on how to get the cert up to the LTM, but haven't found it. I have yet to find a way to import certificates via PowerShell. These questions have been asked for a few years and it doesn't appear F5 is doing anything to help resolve them. Good luck!
  • R_Eastman_13667's avatar
    R_Eastman_13667
    Historic F5 Account
    winscp or scp the certs to the /shared/cert directory, you will have to create the /shared/cert dir. You use your admin management gui username and password to access the directories.
