Mohamed_Lrhazi's avatar
Mohamed_Lrhazi
Mar 21, 2013
Help improve http redirect iRule
I wrote this iRule so that my team could hopefully manage HTTP redirects easily, using a simple string data class with this format :
Host,URI,TARGET_URL,HTTP_CODE
Example:
www.example.com,/,http://target.site.com/path,302
*example.com,/foo/bar*,http://target.site.com/path/two,301
I need it to work on BigIP 10.0.
Any improvement suggestions highly appreciated.
https://gist.github.com/lrhazi/89b466ed2089cb19e6f9
Thanks a lot,
Mohamed.
  • *example.com,/foo/bar*,http://target.site.com/path/two,301is it possible to not use wildcard on http host? if so, i think by modifying data group data a bit we will be able to use "class match" command instead of comparing one by one.
    [root@ve10:Active] config  b class exact_class list
    class exact_class {
       "www.example.com/" { "http://target.site.com/path,302" }
    [root@ve10:Active] config  b class starts_with_class list
    class starts_with_class {
       "bha.example.com/foo/bar" { "http://target.site.com/path/two,301" }
    just my 2 cents
  • Yes, makes sense to sacrifice the wildcarding of hosts for performance. but in my version, I think 10.0, there does not seem to be a way to define a string data group as key and value, but just a list of strings....
    Maybe there is a way though.. am thinking about it....
    I added an improvement to the rule, where the 'taget" field is "eval"ed, so the user could put:
     *.example.com,/foo/bar*,http://target.site.com[HTTP::uri],301
    and it would behave like http classes do.
