Handling self-signed certs with java and iControl
Hi folks -- I'd like to write a couple simple java classes to automate some tasks in our F5 LTM (such as enabling/disabling certain nodes).
To get started I downloaded iControlAssembly_11_3_0-Java.zip, extracted it, and added the iControl.jar and 3rd party (axis.jar,etc) to my development environment, and wrote a simple java program based on one of the examples, to get system info.
The problem I'm hitting is this: we are using a self-signed cert with our F5 LTM, as it's used in a test environment. When I run the java program I get this exception:
AxisFault faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException faultSubcode: faultString: javax.net.ssl.SSLException: hostname in certificate didn't match: < myf5hostname> != faultActor: faultNode: faultDetail: {http://xml.apache.org/axis/}stackTrace:javax.net.ssl.SSLException: hostname in certificate didn't match: != at org.apache.axis.components.net.JSSESocketFactory.verifyHostName(JSSESocketFactory.java:351)at org.apache.axis.components.net.JSSESocketFactory.verifyHostName(JSSESocketFactory.java:287)at org.apache.axis.components.net.JSSESocketFactory.verifyHostName(JSSESocketFactory.java:270)at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:216)
Any thoughts on how I can easily handle this? I'm not sure how to override the Apache SSL verification process, or where to get started, even. :(
Thx!
- What_Lies_Bene1
You can download the certificate file off the F5 device and then import it into your test environment's keystore. I believe the command used to do this is 'keystore'
- Jeff_41325
Another hack is to override the https implementation to not check the cert. Some of these functions are deprecated...
Protocol easyhttps = null; try { easyhttps = new Protocol("https", new EasySSLProtocolSocketFactory(), 443); } catch (GeneralSecurityException e1) { throw new AsmAccessException(e1.getMessage(),e1); } catch (IOException e1) { throw new AsmAccessException(e1.getMessage(),e1); } Protocol.registerProtocol("https", easyhttps); That specific error was something we put in due to an open vulnerability in Apache Axis:
http://web.nvd.nist.gov/view/vuln/detail?vulnId=CVE-2012-5784
We had many customers report this to us and were unable to deploy any iControl applications unless we patched this.
The workaround is to create a local host entry to give a hostname to server hostname so the URL you requested in the connection matches what's in the certificate.
You can also attempt to find an older build of Apache Axis (or download one of the older iControl libraries for Java) and use that version of axis.jar if you are willing to accept this vulnerability in the Apache code.
-Joe
- boo_radley_1114
Thanks Joe -- I spent a couple hours down a nasty rat hole of SSL certificate importing to the eclipse client, etc.
So I have to edit my 'hosts' file on the client with this line: my f5's ip address localhost.localdomain
And then in the java code, the string for the F5 hostname is literally "localhost.localdomain" That does work, but looks odd.
If only NIST hadn't been so lame in reporting that vuln, we could have all lived in peaceful existence with mismatched hostnames...
Pre-11.3, the iControl library distribution included an unpatched version of axis.jar if you want to live on the wild side. I can get you a link if you can't find it on the site.
-Joe
- HERMANN_maurer_
simply renew your certificate on the load balancer itself.
System ›› Device Certificates : Device Certificate ›› Device Certificate
And specify the hostname or IP which does not match in your case at the "Common Name" field.
That should do the job.
/Hermann
