Rob_74473's avatar
Rob_74473
Icon for Cirrus rankCirrus
Apr 25, 2018
Get list of monitors through SDK
I am trying to mimic the Health Monitors section from a pool properties page from the BigIP gui. I need to get a list of all monitors so I can construct a select field in a web page. I have tried several versions of:
for monitor in mgmt.tm.ltm.monitor.get_collection():
        for item in monitor.get_collection():
                pprint(item)
But, this obviously doesn't work. If I could get a list of the monitor types I could iterate through them, but I can't seem to get a list of types either.
  • 'monitor' is another collection with the various monitor types collections inside. You can access to the monitor type collections. Example for TCP:
    tcps_monitors = mgmt.tm.ltm.monitor.tcps.get_collection()
    for monitor in tcps_monitors:
        print "TCP monitors:"
        print monitor.name
        print monitor.interval
        print monitor.timeout
  • From tmsh, type list ltm monitor and TAB completion. You will find the list of monitor types.
    In iControl REST, the /mgmt/tm/ltm/monitor returns a list of objects. Each object represents the endpoint for a type: e.g.,
                "reference": {
                    "link": "https://localhost/mgmt/tm/ltm/monitor/diameter?ver=13.1.0"
    For curl users, it's as simple as grepping the link lines:
     curl -sku admin: https://localhost/mgmt/tm/ltm/monitor | python -m json.tool | grep link
    In Python API, the object is represented as dict, so you can do something like this:
    from f5.bigip import ManagementRoot
    mgmt = ManagementRoot('mgmtPort', 'user', 'pass')
    monitor = mgmt.tm.ltm.monitor.get_collection()
    for t in monitor:
        print(t['reference']['link'])
    You can use the link value as is to obtain the monitors under a specific type.
    for t in monitorTypes:
        endp = 'mgmt.tm.ltm.monitor.' + t + '.get_collection()'
        try:
            e = eval(endp)                      Get list
            eList = map(lambda x: x.name, e)
            print('{}: {}'.format(t, ','.join(eList)))
        except AttributeError:
            print('{} does not exist.'.format(t))
    The code would yield something like this (truncated):
    diameters: diameter
    dns_s: dns
    externals: external
    firepass_s: firepass
    ftps: ftp
    gateway_icmps: gateway_icmp
    https: http,http_head_f5
    https_s: https,https_443,https_head_f5
