13-Jul-2021 01:16
Please share the KB article for generating CSR from F5 with existing private key.
14-Jul-2021 01:54
This is not possible. During creation of CSR, Openssl generate private key.
14-Jul-2021 07:44
You can't generate private key with help of exiting CSR. I can suggest to choose below options.
Option 1: Generate new CSR and share to CERT provider and get cert.
Option 2: Check with Cert provider if they can consider exiting CSR(they have old csr) and share new Public Cert. Then replace exiting cert to new cert in F5.
Note: Take backup before making any changes for Options2
