Sort By
- Deb_Allen_18Historic F5 Accounthttps://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip9_0config/ConfigGuide9_0-07-1.html?sr=1
- IT_Support_5777NimbostratusThank you for the link, although this doesn't illustrate how to set this up. the problem I am having is that I can use passive FTP and I have no issues connecting and sending data through the LTM. Active does not work though. I am using the default FTP profile that seems to account for port 20 activity.
- Deb_Allen_18Historic F5 AccountClient contacts LTM on port 21, LTM forwards to server on LB port, server contacts client to est data connection on port 20.
- IT_Support_5777Nimbostratusyeah...no go. I will contact support.
- danzisar_19807NimbostratusDid you ever receive an answer from support? I am having the same issue.
- IT_Support_5777Nimbostratusyeah, it is brutal though and IIRC, it led me to believe that active connections are better handled another way, through static NAT on my router/firewall.
- brad_11480Nimbostratussimilar/same issue here. i have a checkpoint firewall. seems that this works fine as long as the F5 and ftp servers are 'inside' the firewall but as soon as i try to pass through the firewall it doesn't go too well.
