Technical Forum
Custom Alert Banner
Error while accessing a resource in APM : Missing route token in request
Abhijith_KS
Hi All,
We have View VDI set up with our F5 APM, and when I try to connect I can login with my AD credentials and when I try to access a resource via HTML I get the error message saying "Missing route token in request". Has anyone faced this ? also we are using View 6.
Abhijith.
1 REPLY 1
brinkernate
I'm running into the same issues. was this ever solved?
