mElhoussini_204's avatar
mElhoussini_204
Aug 30, 2015
Disable Directly connected Routing
our servers gateway is a FW , F5 has an interface in each server vlan so if one server configured to let F5 to be its GW the traffic will bypass the FW so can we disable directly connected routing ?
  • The f5 will not forward the traffic like a router unless you configure the behaviour with a virtual server.
