07-Aug-2022 01:24
I would like ot know the procedure for creating CSR, key and importing the certificate on LTM v 13. I am using configuration utility. I have seens some procedures but I do not see procedure for generating key using config utility?
Can you please guide?
Solved! Go to Solution.
07-Aug-2022 19:19 - edited 07-Aug-2022 19:20
Hi @faadi777 ,
When you create CSR on the F5, there are fields for the key properties e.g. key type and size. So once you finish it, private key is also generated simultaneouly. Key should be available under below section.
You can refer section 'Create an SSL CSR and private key' under below ref article.
https://support.f5.com/csp/article/K14620#2
Hope it helps!
Hi @faadi777 ,
Hope it helps!
