mzimmer3_65389's avatar
mzimmer3_65389
Apr 24, 2009
Broken pipe with oneconnect
Platform: ltm 6400 9.4.X
when I enable oneconnect on our f5 I get random issues in our apache server. Here is the log entry:
(32)Broken pipe: core_output_filter: writing data to the network
Has anybody experienced this issue when enabling oneconnect?
Thanks,
  • Broken pipe errors are very common, so it's a little tough to say - a user hitting the 'stop' button on their browser can cause this, for example. What is your apache's KeepAlive directive set to? Have you changed the mask settings on your oneconnect profile? If so, has that made any difference?
    -Matt
