10-Nov-2023 09:23
Is anyone pulling traffic reports/stats from their Big-IP appliances, specifically the vservers? What we're using are v14 (going to v15 next month) VEs, LTM only. If so, what tools are you using and what would you recommend?
Thanks!
Solved! Go to Solution.
12-Nov-2023 04:24
HI @Fallout1984 ,
No tools will do this efficiently more than AVR and analytics profile.
But be careful >> Adding much Virtual servers within Analytics profiles or AVR engin may exhauist your system resources so keep your eyes in your system CPU and memory.
also look at avrd service and how it consumes from CPU periodically.
10-Nov-2023 09:32
I'm just now looking at AVR and intend to go through the free intro class at:
https://clouddocs.f5.com/training/community/analytics/html/class1/class1.html
That being the case, any tips, possible gotchas, alternatives, etc. would be appreciated.
Thanks!
12-Nov-2023 04:24
HI @Fallout1984 ,
13-Nov-2023 09:40
@Fallout1984 - If your requirement is to extract the VS and its stats, you can try this codeshare.
13-Nov-2023 11:05
That's interesting - thanks! 😀
