Igor430's avatar
Igor430
Feb 09, 2022
Solved
Assign cookie value to APM custom variable
Hey all,
Looking for help to create an irule that would check for the XSRF-TOKEN cookie in the HTTP request and if it exists, assign the cookie value to a custom APM variable (for example, session.custom.xsrftoken)
Thank you
  • I believe that something like this should work:
    when ACCESS_ACL_ALLOWED {
    if { [HTTP::cookie exists "XSRF-TOKEN"] } {
    ACCESS::session data set session.custom.xsrftoken [HTTP::cookie value XSRF-TOKEN]
