Dali's avatar
Dali
Jun 16, 2022
Solved
ASM Captcha for registering page (not login page) - possible or APM modul needed?
Hello,
I need to use ASM Captcha feature for registering page - it means Captcha is active/visible from the first client attepmt/access of the registering page to prevent robots of creating accounts. (application is not compatible with google recaptcha so I try find out substitution of it).
Is it needed to use Captcha feature via APM (not ASM)?
OR
the use of ASM Bot defense can help with this?
Thank you for advice in advance,
Dalibor
