Snl's avatar
Snl
Aug 08, 2019
APM sso cookie caching issue
Folks
need some help , i have VS were using APM SSO for my jboss web application which working fine with kerberous SSO , the problem is this web doesnt hve logout option , user will close the browser directly , but next time same user open in the same url in the browser APM redirecting to ADFS SSO and getting 302 redirect with CORS error
i want to get rid of previously used MHRsesion cookie so that every time browser come with new request (after closed the page and open the url again)were APM assign new cookie for SSO session , when i try chrome incognito its working fine since it doesnt store any cache or APM cookie
can below irule help
#fire irule before main SSO irule to remove last browser used apm session cookie for previous session
when HTTP_REQUEST priority 80 {
 if { ([HTTP::uri] == "/") && [HTTP::cookie exists MRHSession ] && [ACCESS::session exists [HTTP::cookie value MRHSession]] }{
 HTTP::cookie remove MRHSession }{
HTTP::redirect "https://log.abc.com[HTTP::uri]"
any help appreciated
  • Snl's avatar
    Snl
    or just remove the session cookie
  • Sajid's avatar
    Sajid
        ACCESS::session remove
    https://clouddocs.f5.com/api/irules/ACCESS__session.html
    for reference
    if {[HTTP::path] contains "/public" } {
    HTTP::cookie remove "LastMRH_Session"
    HTTP::cookie remove "MRHSession"
    for reference
    HTTP::redirect "https://[HTTP::host]/vdesk/webtop.eui?webtop=/Common/dfw_vpn_webtop&webtop_type=webtop_full"
    } elseif { [HTTP::cookie exists MRHSession] } {
  • Snl's avatar
    Snl
    Hi Sajid
    I have seen this irules earlier , my concern is what is the best way to avoid using existing APM session cookie , i am not concern for SSO , user needs re authenticate every time if they close the browser
    so what is the best way forward here
    • not quite sure what you are looking for now.
      the best way to avoid using existing APM session cookies is to not send them from the browser. but if they still exist you have to get them deleted. does iRules can that do that.
      what more are you looking for now?
      • Snl's avatar
        Snl
        Hi Boneyard
        does below irule will work ?
