5 Comments
  • Is this also being worked on to provide secure access and load balancing for Horizon DaaS (formerly Desktone) and Horizon Workspace as well?
    If you can provide one solution that can be used for the Horizon Suite, it will be far too compelling to pass up or ignore.
    Cheers!
  • Hi O'Brien,
    Both Horizon Workspace and DaaS are on our list of solutions to investigate, test, and create deployment guidance for, but we do not have anything yet. We did notice this article on the VMware communities page for Workspace 1.5 and F5, it may be helpful (https://communities.vmware.com/docs/DOC-24577)
    Joe
  • The PCoIP proxy solution with BIG-IP works like a charm. Are there any other than RSA OTP options available or is this restricted by the Horizon View client itself?
  • Thanks very much for this, Do you think you will have support for View 6? It would seem in our environment that the current iApp doesn't seem to work with the latest view client (iOS)
  • any (new) deployment guide for Horizon Workspace? SAML support?
