on 20-Apr-2017 08:00
As the lines between DevOps and NetOps continue to blur thanks to the highly distributed models of modern application architectures, there rises a need to understand the difference between load balancing and application routing. These are not the same thing, even though they might be provided by the same service.
Load balancing is designed to provide availability through horizontal scale. To scale an application, a load balancer distributes requests across a pool (farm, cluster, whatevs) of duplicated applications (or services). The decision on which pool member gets to respond to a request is based on an algorithm. That algorithm can be quite apathetic as to whether or the chosen pool member is capable of responding or it can be “smart” about its decision, factoring in response times, current load, and even weighting decisions based on all of the above.
This is the most basic load balancing pattern in existence. It’s been the foundation for availability (scale and failover) since 1996.
Load balancing of this kind is what we often (fondly) refer to as “dumb”. That’s because it’s almost always based on TCP (layer 4 of the OSI stack). Like honey badger, it don’t care about the application (or its protocols) at all. All it worries about is receiving a TCP connection request and matching it up with one of the members in the appropriate pool. It’s not necessarily efficient, but gosh darn it, it works and it works well. Systems have progressed to the point that purpose-built software designed to do nothing but load balancing can manage millions of connections simultaneously. It’s really quite amazing if you’re at all aware that back in the early 2000s most systems could only handle on the order of thousands of simultaneous requests.
Now, application routing is something altogether different. First, it requires the system to care about the application and its protocols. That’s because in order to route an application request, the target must first be identified. This identification can be as simple as “what’s the host name” to something as complicated as “what’s the value of an element hidden somewhere in the payload in the form of a JSON key:value pair or XML element.” In between lies the most common application identifier – the URI.
Application “routes” can be deduced from the URI by examining its path and extracting certain pieces. This is akin to routing in Express (one of the more popular node.js API frameworks). A URI path in the form of: /user/profile/xxxxx – where xxxxx is an actual user name or account number – can be split apart and used to “route” the request to a specific pool for load balancing or to a designated member (application/service instance).
This happens at the “virtual server” construct of the load balancer using some sort of policy or code.
Application routing occurs before the load balancing decision. In effect, application routing enables a single load balancer to distribute requests intelligently across multiple applications or services. If you consider modern microservices-based applications combined with APIs (URIs representing specific requests) you can see how this type of functionality becomes useful. An API can be represented as a single domain (api.example.com) to the client, but behind the scenes it is actually comprised of multiple applications or services that are scaled individually using a combination of application routing and load balancing.
One of the reasons (aside from my pedantic nature) to understand the difference between application routing and load balancing is that the two are not interchangeable. Routing makes a decision on where to forward something – a packet, an application request, an approval in your business workflow. Load balancing distributes something (packets, requests, approval) across a set of resources designed to process that something. You really can’t (shouldn’t) substitute one for the other. But what it also means is that you have freedom to mix and match how these two interact with one another.
You can, for example, use plain old load balancing (POLB) for ingress load balancing and then use application routing (layer 7) to distribute requests (inside a container cluster, perhaps). You can also switch that around and use application routing for ingress traffic, distributing it via POLB inside the application architecture.
Load balancing and application routing can be layered, as well, to achieve specific goals with respect to availability and scale. I prefer to use application routing at the ingress because it enables greater variety and granularity in implementing both operational and application architectures more supportive of modern deployment patterns.
The decision on where to use POLB vs application routing is largely based on application architecture and requirements. Scale can be achieved with both, though with differing levels of efficacy. That discussion is beyond the scope of today’s post, but there are trade-offs.
It cannot be said often enough that the key to scaling applications today is about architectures, not algorithms. Understanding the differences of application routing and load balancing should provide a solid basis for designing highly scalable architectures.
Some are better for gaming as well as some are much better for setting upVisit This LinkIf you have a compatible router you should, really just obtain one.
Car liker is launched and it is presently offeredhttp://machineliker.meclicking the download web links and install it on.
I've been pondering over this concept for weeks and eventually landed this right place. You can visit my findings here.
TV box is one of the best ways to improvehttps://bestandroidtvbox.coby having Alexa do all the work for you.
And one such is the Desire Organization Football video game.Dream League Soccer 2017 DownloadAs well as if you comply with the actions over meticulously it will
