on 13-Jul-2016 11:21
Many web applications are using encryption (TLS) for security, but security typically slows things down. Is it possible to implement a good TLS solution but still keep the speed you want? In this video, I dig into the tension between security and speed, and how TLS protocol extensions can help performance. Turns out, you can have your speed and security too!
Brian McHenry wrote a great article here on DevCentral that outlines all this as well. Check it out here: https://devcentral.f5.com/s/articles/a-green-light-for-tls
