on 22-Jul-2014 12:37
Many customers express interest to use F5 Access Policy Manager for transparent seamless authentication for their users. There are a couple of leading use cases that drive that desired behavior:
APM can perform three types of 401-based challenge authentication: Basic, NTLM, and Kerberos. Basic always requires user’s intervention, but Kerberos and NTLM can enable users to seamlessly authenticate to the APM virtual server and allow it to either securely proxy connection to the backend application such as Sharepoint, leveraging Kerberos Constrained Delegation as the SSO mechanism, or acting as SAML IDP and issuing assertions to the SAML Service Providers based upon user identity extracted during NTLM authentication or Kerberos ticket.
Today, we are going to examine the second use case on how to configure APM to perform client NTLM authentication and use it in the context of sending a SAML assertion to the Office 365 service. It is assumed below that user knows how to configure APM for standard forms-based authentication and also has at least one existing policy(although you can create a new one from the scratch). One of the easiest ways to test this is to deploy the Office 365 configuration using the iApp and the modify configuration to enable NTLM authentication. The steps below assume that you either have a working Office 365 configuration based on the iApp, or you have an equivalent policy that you can modify.
Keep in mind that you will need to create a unique account in Active Directory for your BIG-IP. In the example above, the account name is bigip1.
when RULE_INIT { set static::appname_ntlm_retries 2 set static::appname_ntlm_config "/Common/appname_ntlm_config" set static::appname_access_log_prefix "01490000:7:" set static::appname_ntlm_on_demand_prfx "$static::appname_access_log_prefix \[NTLM-ON-DEMAND\]" } when ACCESS_SESSION_STARTED { ACCESS::session data set "session.ntlm.last.retries" 0 } when HTTP_REQUEST { log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx Request: [HTTP::uri]" switch -glob -- [string tolower [HTTP::uri]] { "/ntlm/auth" { set sid [ACCESS::session sid] log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx sid: $sid" set referer [HTTP::header value Referer] log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx Referer: $referer" set x_session_id [ HTTP::header value X-Session-Id ] if { [ string length $x_session_id ] != 0 } { set sid $x_session_id } set retries [ACCESS::session data get -sid $sid "session.ntlm.last.retries"] log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx retries: $retries" set auth_result [ACCESS::session data get -sid $sid "session.ntlm.last.result"] log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx auth result: $auth_result" if { ($auth_result == 1) || ($retries == $static::appname_ntlm_retries) && ($auth_result != 1) } { ECA::disable log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx Redirect to: $referer" HTTP::redirect "$referer" } else { ECA::enable ECA::select select_ntlm:$static::appname_ntlm_config } unset x_session_id unset referer } default { ECA::disable } } } when CLIENT_ACCEPTED { set second_pass pass[IP::client_addr][TCP::client_port] # Check if this is the first or second time passing through this virtual if { [ table lookup $second_pass ] == "1" } { set wait_timeout 3000 set wait_delay 100 set wait_total 0 set disable_ssl disablessl[IP::client_addr][TCP::client_port] # Wait for SERVER_CONNECTED event to complete while { [ table lookup $disable_ssl ] != 0 && [ table lookup $disable_ssl ] != 1 && $wait_total < $wait_timeout } { set wait_total [ expr "$wait_total + $wait_delay" ] after $wait_delay } unset wait_delay wait_timeout # Check table value set by SERVER_CONNECTED to disable ssl set disable_ssl_value [ table lookup $disable_ssl ] if { $disable_ssl_value == "1" } { set command "SSL::disable" eval $command unset command } elseif { $disable_ssl_value != 0 } { log -noname accesscontrol.local1.notice "$static::appname_ntlm_on_demand_prfx Error: SERVER_CONNECTED event not completed after $wait_total ms" } table delete $disable_ssl table delete $second_pass unset disable_ssl wait_total } else { # This is the first time through this virtual. Set clientssl flag set client_ssl clientssl[IP::client_addr][TCP::client_port] if { [ catch { PROFILE::clientssl name } ] } { table add $client_ssl "0" } else { table add $client_ssl "1" } unset client_ssl } unset second_pass } when SERVER_CONNECTED { set client_ssl clientssl[IP::client_addr][TCP::client_port] set disable_ssl_value 0 # Check clientssl flag set from CLIENT_ACCEPTED. if { [ table lookup $client_ssl ] == "1" } { if { [ catch { PROFILE::serverssl name } ] } { # Clientssl is present but serverssl is not. Disable clientssl set disable_ssl_value 1 } table delete $client_ssl } set disable_ssl disablessl[IP::client_addr][TCP::client_port] table add $disable_ssl $disable_ssl_value unset disable_ssl unset client_ssl disable_ssl_value } when ECA_REQUEST_ALLOWED { log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx NTLM Auth succeed" ACCESS::session data set session.ntlm.last.username "[ECA::username]" ACCESS::session data set session.ntlm.last.domainname "[ECA::domainname]" ACCESS::session data set session.ntlm.last.machinename "[ECA::client_machine_name]" ACCESS::session data set session.ntlm.last.status "[ECA::status]" ACCESS::session data set session.ntlm.last.result 1 ACCESS::disable HTTP::header insert X-Session-Id $sid log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx use virtual: [ virtual name ]" # Set flag for next CLIENT_ACCEPTED telling it that it is the second pass through virtual set second_pass pass[IP::client_addr][TCP::client_port] table add $second_pass "1" unset second_pass # Connect to itself in order to generate HTTP response use virtual [ virtual name ] } when ECA_REQUEST_DENIED { log -noname accesscontrol.local1.debug "$static::appname_ntlm_on_demand_prfx NTLM Auth succeed" if { [ACCESS::session data get session.ntlm.last.retries] != $static::appname_ntlm_retries } { incr retries ACCESS::session data set session.ntlm.last.retries $retries } }
After creating this iRule, assign it to the APM Virtual Server.
Let’s examine how the policy depicted above is structured. The assumption is that the policy is going to be used to authenticate both internal and external users. If the users are coming in from the internal corporate network, we want to steer them straight to the NTLM authentication, if not, we want to use forms-based login for to authenticate them. I’ve started the policy with IP Subnet Match action to steer clients from certain networks to the NTLM authentication.
Once the desired source networks are matched, we create an External Login Page object that will send user back to the APM virtual and request NTLM authentication.
After sending the user to the “external login page”, which in fact is just a request to the same virtual server that is handled by the iRule that enables NTLM authentication between the client and BIG-IP, we need to check the status of the NTLM authentication, so we add the “NTLM Auth Result Check” action to see if the NTLM authentication was successful. If so, we need to populate the username session variable to enable APM to use it in session reporting/tracking, SAML assertion, SSO, etc.
Now you can assign necessary resources to the user session. In this example, we are assigning APM to act as the IDP to Office 365.
After you finished creating or modifying the Access Policy, make sure it is assigned to the APM virtual.
6. Next, we need to modify how the virtual server handles preservation of the original source port of the connection. This can be done either from the BIG-IP Administrative interface, or from the command line. Both examples are shown below.
7. Last, but not least, you need ensure that the machine you’re using to achieve the silent sign-on has the APM Virtual FQDN added to its Local Intranet zone as per the picture below.
Voila! You should be all set. Point your browser on the machine to the FQDN of the APM Virtual Server where you assigned the new policy and iRule, and you should be silently authenticated. If you are interested in performing SSO to applications such as Sharepoint, you will need to setup Kerberos SSO in order to perform single sign-on to the Sharepoint based on the NTLM authentication.
Great article!
I was wondering what the eca profile exaclty does. It is not documented very well in the manuals. Could you elaborate the funcionality of it?
Did the test with the provided iRule but are always getting the following error message
Did you have any idea of what could be wrong?
Seems that there is a new session that trigger this event...
Thanks!
Access policy evaluation is already in progress for your current session.
You may see this message, if you are using a different browser tab than the one where you started the access policy initially. Please continue to finish your access policy in the previous browser tab, and close this current window immediately.
If you have reached to this message due to some other error, click here for creating a new session.
Thank you. I'm trying to leverage this seamless approach for my sharepoint and some other web app deployment (for sharepoint kerberos, for other apps, ntlm & form based)
I'm trying to get basic setup just to start and I'm getting this error message
bad sid value length (line 1)variable lookup failed (line 1)Illegal argument (line 1) (line 1) invoked from within "ACCESS::session data get -sid $sid "session.ntlm.last.retries""
Any ideas?
I'm 11.5.3 and hoping to get this working. when i set up the machine connection to AD and then define the servers it seems to register fine.. but then i get errors in the log saying init: Error 1, NT_STATUS_UNSUCCESSFUL.
we can't figure out why this is.. and it ust doesn't work. thanks.
Bump.. so now at version 12 and still nothing working. is there a good, proven, guide for setting up NTLM with APM. Here I want it as part of SAML/SSO.
I am also seeing the error: TCL error: bad sid value length but only for Firefox and intermittently. I can recreate the issue by creating a new profile in FF and then trying the NTLM auth, and it fails with the TCL error, if I close the window and try again it works. Anyone have issues with Firefox???
I'm beginning to think taht NTLM auth with SAML/SSO is a futzz at best and is unworkable in general. I can get some of it to work with Firefox, others to work in Chrome, none to work in IE.
In Chrome on one of them i see LTM reporting: warning tmm[19392]: 01480001:4: No held transaction to sink. The mentions of it in Devcentral relate to ASM and not APM. While it says warning, the client browser just spins waiting fora response from the IdP.
In IE the error is: Nov 17 08:07:27 slot1/f5ext1a err tmm1[19392]: 014d0002:3: 25408ee6: SSOv2 POST Authn Request has no body Nov 17 08:07:27 slot1/f5ext1a err tmm1[19392]: 014d0002:3: 25408ee6: SSOv2 Error(12) Extracting SAML Data from Request
I don't use the code above in version 12 as I understood this was all now a working feature.
If anyone has a solid working solution, it would very much be appreciated. Thanks so much.
Hey Brad, the first error from the TMM mentions 'no body' in the POST request. SAML uses security assertions, logically APM system leverages BIGIP HTTP capabilities via the TMM and websso daemon to handle Authn requests via HTTP (POST) requests.
You could put websso to see what HTTP requests/data it gets in debug but the error sequence is similar to ID 667600:
K34203924: A newly created Kerberos access policy authentication agent may default to request-based authentication | https://support.f5.com/csp/article/K34203924
Looks like this ID requires RBA, you can see if the conditions and workaround apply for you:
To work around this issue, you can change the access policy Kerberos authentication agent properties Request Based Auth setting to disabled. To do so, perform the following procedure:
Impact of workaround: Performing the following procedure should not have a negative impact on your system.
Log in to the Configuration utility. Navigate to Access Profiles/Policies. To open the visual policy editor, click the Edit link to the right of the affected access profile name. Click the Kerberos Auth box. From the menu, toggle the setting for Request Based Auth to Disabled. Click Save. Click Apply Access Policy.
~skye
Hello - IN the process of learning a lot about the F5 stuff, so it is quite possible i overlooked something in the setup of this - but when i apply the iRule to my VIP, it seems like clients that match the IP subnet get "page cannot be displayed" because the connection was refused, and when the ipsubnet is not matched they get the forms login page - which seems to be fine. Any ideas on this?
Thanks in advance.
Hello - When setting this up, the NTLM piece works good - but after that, i get a SAML error when trying to connect to the webtops. It works fine for machines that are not on the ipsubnet match, but doesnt for the machines that are on the subnet match. Is there something in the irule that I would need to adjust? Thank you
A client is requiring exactly the same setup for internal users. If I understand correctly this will mean the F5 to be able to poll all internal clients using NTLM and also verify the result with the AD server?
So firewall rule would be F5 Self IP --> all internal clients using UDP/TCP 137/138? Isn't this a security risk allowing a DMZ device to contact internal client on this port number?
For anyone reading this article and trying to use any code forward of 14.1.0 you should know NTLM is broken.
https://cdn.f5.com/product/bugtracker/ID797541.html
Further if you go to a Kerberos config and you leave this setting enabled from this guide.
For Source Port, select Preserve Strict.
You will get resets on the VIP, it won't show up in testing until someone else tries using it. I put it through Dev, went to production and released it. Then I raised a Sev2, it wasn't immediately obvious for support either. It's taken 24 hours to resolve....
