on
30-Mar-2023
05:00
- edited on
24-May-2023
14:55
by
LiefZimmerman
The Secure Sockets Layer (SSL) protocol and its successor, Transport Layer Security (TLS), are being widely adopted by organizations to secure IP communications. While SSL/TLS provides data privacy and secure communications, it also creates challenges to inspection devices in the security stack. What if attackers are hiding malware inside the encrypted traffic?
An integrated F5 and Cisco WSA solution solves the SSL/TLS challenges. F5 BIG-IP SSL Orchestrator centralizes SSL/TLS inspection. The decrypted traffic is then inspected by one or more Cisco WSA VMs, which can block previously hidden threats. This solution eliminates the blind spots introduced by SSL/TLS.
This article assumes you have SSL Orchestrator configured with a Topology and Service Chain.
The Network Adapters should be configured like the following:
Create a Port Group for BIG-IP to connect to the P1 interfaces (Network Adapter 2) of the WSA VMs. The ESX vSwitch topology should be configured as follows:
Select Network > Interfaces
Configure the Interfaces as follows:
Note: make sure to select the option to Restrict M1 port to appliance management services only
Configure the Virtual Machine Network Adapters as follows:
The BIG-IP VLAN settings should look like the following:
The BIG-IP Self IPs setting should look like the following:
Note: in this example SSL Orchestrator is deployed with an L3 Inbound Topology. That’s what the other two Self IPs are for. Your configuration will look different if using an L2 Topology.
Navigate to SSL Orchestrator > Configuration.
Under Services, click Add.
In the Service Catalog select the Inline HTTP tab then double click on Cisco WSA HTTP Proxy.
Give it a name, CISCO_WSA in this example.
Under Service Definition unselect the option to Auto Manage Addresses.
For the To Service VLAN select 10.0.0.1 (VLAN TO_WSA).
Click Add for HTTP Proxy Devices.
Enter the WSA IP address, 10.0.0.25 in this example.
Click Done.
Click Add to add the IP address of the 2nd Cisco WSA, 10.0.0.30 in this example.
It should look like the following:
For the From Service VLAN select 10.0.0.1 (VLAN TO_WSA).
Click Save & Next at the bottom.
Click the name of the Service Chain.
Select the CISCO_WSA Service from the left and click the arrow to move it to the right. Click Save.
Click OK
Click Deploy
Click OK to the Success message.
When done it should look like the following:
From the Services screen if you expand the Pool Member Status you should see both Cisco WSA VMs.
In this example there is a Windows client that connects through the SSL Orchestrator to a Windows server running the following web site:
Test this connection now and it should look like the following:
In this example Cisco WSA is configured with a Custom Category to block connections to http://192.168.0.99. When attempting to connect to this site with a web browser you should see a block page like the following:
Note: in the block page you can see Cisco WSA has identified this site as HTTP and not HTTPS. This is because SSL Orchestrator has decrypted the HTTPS and sent the content to Cisco WSA as HTTP.
Check the Dashboard on the Cisco WSA and you should see something like the following:
Here you can see the allowed (Clean) and denied (Suspect) connections.
This completes configuration of BIG-IP SSL Orchestrator with Cisco WSA Virtual Edition. At this point traffic that flows through SSL orchestrator will be decrypted and sent to the Cisco WSA Service and inspected for malicious payloads or policy violations.
