Watch how F5 customers can now simply use BIG-IP Access Policy Manager or BIG-IP Edge Gateway to consolidate access control in a central location, keeping infrastructure administration concerns to a minimum. With BIG-IP solutions, customers enjoy the flexibility and scalability needed to extend Citrix applications to both local and remote users without changing local XenApp deployments or requiring STA to provide secure remote access to applications.
Highlights of deploying Citrix and F5 technologies together include:
Reduced Management Time and OpEx – By simplifying and centralizing local and remote access authentication, BIG-IP solutions eliminate the need for customers to add separate Citrix STA infrastructure or make changes to existing Web Interface servers, resulting in an environment that is less expensive to deploy and requires less time to manage.
Simplified Configuration and Deployment – With BIG-IP solutions, administrators can support users of Citrix applications with fewer devices, configure deployments to support flexible access models, and easily scale the environment. This fully integrated functionality makes it quick and easy for customers to set up and deploy local and remote access capabilities for Citrix applications, keeping users productive.
Centralized and Comprehensive Access Control – Unlike the separate Citrix products required to adequately support applications for remote users, BIG-IP solutions provide centralized application access control and use a single access policy to support all types of users securely, so IT teams can be confident that application access is aligned with the organizations’ specific business priorities and security policies.
Video needs to be renamed - "Some Dude Using Xenapp while saying "F5 APM.: It provided no real value. Actually since it is 4 years old, it may as well just be removed....
