Technical Articles
F5 SMEs share good practice.
Chase_Abbott
F5 Employee
F5 Employee
BIG-IQ 7 is out now and improving on the integration with our Application Services 3 Extension (AS3) released in BIG-IQ 6.1. In the below video, Aaron Johnson walks you through deploying application services in two datacenters, managing them all within BIG-IQ.
If you're not familiar with AS3, it's F5's lightweight Javascript iControlLX plug-in offering declarative interfaces for application management. Read more on AS3 at Clouddocs.f5.com.
For BIG-IQ 7.0 and above, F5's AS3 template library referenced in the video is available at DevCentral's GitHub Organization .
Comments
Dojs
Great article
Kenji_Omori
I think that AS3 enhancement on v7 is good.
Also, if BIG-IQ can create/modify/delete any object in specific partition using Application Templace feature(not AS3), that will get even better.
Version history
Last update:
‎30-Sep-2019 13:04
Updated by:
Contributors
