Technical Articles
F5 SMEs share good practice.
Recently, there's been some "buzz" around how to configure Dell vWorkspace components behind BIG-IP's Local Traffic Manager. A few months back, I had the opportunity to work with Stephen Yorke from the Dell vWorkspace team to put together a configuration that helps provide availabilty and resiliency for vWorkspace, including the Secure Access components.
Kelly Craig has graciously taken the good work between Dell and F5 and posted the configuration steps to get this up and running. You can check out his blog post here:
http://en.community.dell.com/techcenter/virtualization/vworkspace/b/vworkspace-blog/archive/2015/05/...
Version history
Last update:
‎04-Jun-2015 16:53
Updated by:
Contributors
