Technical Articles
F5 SMEs share good practice.
Custom Alert Banner
Jeff_Costlow_10
Historic F5 Account
Incorrect TLS padding could be accepted when terminating TLS 1.x CBC cipher connections. F5 has fetched CVE-2014-8730 for this issue.
This issue does not affect the management interface, only the traffic interfaces and does affect all released versions of BIG-IP except the latest version, 11.6.0.
Customers should upgrade to hotfixed releases. See the F5 solution article for this issue for more information.
If you cannot upgrade, then we advise using TLSv1.2 with AES-GCM ciphers (requires BIG-IP v11.5.0 or later and recent clients).
If you cannot upgrade and cannot use AES-GCM ciphers, then we recommend using RC4 ciphers until you can upgrade.
See this solution for more information on setting TLS cipher strings.
Comments
LyonsG_85618
Jeff - we currently use the following cipher settings: RC4-SHA:HIGH:MEDIUM:!SSLv2:!SSLv3:!ADH However according to https://www.ssllabs.com/ssltest/ we are still showing as vulerable. Any ideas why this woudl be?
Mike_Maher
So is it ok to use AES-265-SHA and AES-128-SHA?
brad_11480
So I added this string to our existing cipher string. It still grades us as "F". Rather than the two POODLE attack marks-- SSL 3 and TLS, now it only shows the TLS. I expected that one to go away and end up with the SSL 3, whose grade is capped at "C". The string I set is: 'ALL:!ADH:!LOW:!EXP:!NULL:RC4+RSA:+HIGH:+MEDIUM:!SSLV3:RC4-SHA'
brad_11480
my bad MY [long] cipher string was allowing other ciphers.. Using the recommended 'patch' of the !SSLV3:RC4-SHA on version 11.4.1 leaves me with no SSLv3 and 3 ciphers for TLS1, 1.1, 1.2 RC4-SHA. What client issues will I end up running into?
Jeff_Costlow_10
Historic F5 Account
AES-128-SHA and AES-256-SHA are both CBC ciphers and are susceptible to this issue. RC4-SHA is recommended over AES-CBC ciphers until you patch. SSLLabs is looking for CBC ciphers. On my BIG-IP 11.6.0, the cipher string "RC4-SHA:HIGH:MEDIUM:!SSLv2:!SSLv3:!ADH:-AES:-MD5" removes the vulnerable AES-CBC ciphers and correctly leaves the AES-GCM ciphers. You can use tmm --clientciphers to see the accepted ciphers. See solution 15194 https://support.f5.com/kb/en-us/solutions/public/15000/100/sol15194.html
arai_a_5902
> This issue does not affect the management interface, I don't understand why you say this, Do you say management access (GUI) isn't affected by this?
I did some testing tonight and the cipher string provided in sol15882 results in an F at SSL Labs' testing site, due to ciphers using ADH key exchange. I'm not an expert, so I am not certain how risky having this enabled is. Disabling anonymous Diffie-Hellman (ADH) key exchange bumps the score from a F to a B, using "!ADH:!SSLv3:AES-GCM:RC4-SHA". Using RC4 caps the score at B. Disabling RC4 results in an A rating, but it's likely that a majority of users won't be able to access your site.
arai_a_5902
goutham
Hello jeff, I am running 11.4.0 HF5..can I just address the padding issue by removing !SSLv3 from the cpher string "!SSLv3:RC4-SHA"?? what I meant to say is I dont want to disable SSLv3 and at the same time I want to address the new padding (TLS1.x) issue..
Arie
Altostratus
Altostratus
At least one of the cloud-based services that connect to our systems seems choke on the custom cipher. Do your regression testing...
Jeff_Costlow_10
Historic F5 Account
arai.a: Correct, This issue does not affect the management GUI. goutham: Your proposed cipher string of "RC4-SHA" would avoid this issue as well as SSLv3 POODLE. However, RC4 has known weaknesses and should not be a long term solution. I would suggest patching when possible. Josh: Disabling ADH ciphers is probably not a problem for anyone; ADH is rarely used. I agree with your conclusion that AES-GCM may be restrictive until more browsers have been updated.
jba3126
Cirrus
Cirrus
LyonsG - It's because you are still allowing the CBC Ciphers with that string. Depending on your version of OS (mine 10.2.4) you are still allowing the CBC ciphers: tmm --clientciphers 'RC4-SHA:HIGH:MEDIUM:!SSLv2:!SSLv3:!ADH' ID SUITE BITS PROT METHOD CIPHER MAC KEYX 0: 5 RC4-SHA 128 TLS1 Native RC4 SHA RSA 1: 5 RC4-SHA 128 TLS1.2 Native RC4 SHA RSA 2: 53 AES256-SHA 256 TLS1 Native AES SHA RSA 3: 53 AES256-SHA 256 TLS1.2 Native AES SHA RSA 4: 53 AES256-SHA 256 DTLS1 Native AES SHA RSA 5: 10 DES-CBC3-SHA 192 TLS1 Native DES SHA RSA 6: 10 DES-CBC3-SHA 192 TLS1.2 Native DES SHA RSA 7: 10 DES-CBC3-SHA 192 DTLS1 Native DES SHA RSA 8: 61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA 9: 4 RC4-MD5 128 TLS1 Native RC4 MD5 RSA 10: 4 RC4-MD5 128 TLS1.2 Native RC4 MD5 RSA 11: 47 AES128-SHA 128 TLS1 Native AES SHA RSA 12: 47 AES128-SHA 128 TLS1.2 Native AES SHA RSA 13: 47 AES128-SHA 128 DTLS1 Native AES SHA RSA 14: 60 AES128-SHA256 128 TLS1.2 Native AES SHA256 RSA
kridsana
Cirrocumulus
Cirrocumulus
Is RC4-SHA support all of browser ? We can't upgrade now but not sure if change cipher to RC4-SHA will work without fail. (Not concern about RC4 weakness)
kridsana
Cirrocumulus
Cirrocumulus
From ssllab result, It's seem RC4-SHA not support with IE6/xp. And Did some browser like firefox or chrome with older version support RC4-SHA?
Cyril_M
Altostratus
Altostratus
Hi, why is there still no patch for the v11.3 whereas they are available for v11.2.1 and v11.4.0 ? What's wrong with this version ? :) https://support.f5.com/kb/en-us/solutions/public/15000/800/sol15882.html Thanks
brad_11480
upgraded the systems to the HF6 as recommended. Now TMM keeps restarting on the standby system. Others experiencing similar? Support isn't providing too much information but I'm understanding that others may have a similar problem with HF6.
Chris_G_01_1415
Brad, We are running HF6 and not having any issues at all
RobertS1
Dont use 11.4.1 HF6 or 11.5.1 HF6 if you use APM. There is a critical bug in HF6 involving APM. If you use HF6 and APM contact support they should be able to give you an engineering hotfix. Or wait for an update should be soon within a week.
Michael_Voight_
Historic F5 Account
11.3.0 is End Of Software Development This means there will be no standard hotfix (Reference Solution 5903 at ask5.com) for more info. There are engineering hotfixes that are built that have the fix.
MWat0815_185830
If we can't apply a patch which f5 provided, is invalidating CBC mode effective against this vulnerability?
Version history
Last update:
‎08-Dec-2014 10:09
Updated by:
Contributors
