Technical Articles
F5 SMEs share good practice.
Claudia_Kraus_3
Historic F5 Account
Good to see: http://searchsecurity.techtarget.com/magazineContent/Best-secure-remote-access-products-2011
F5 Networks BIG-IP Edge Gateway brought home the gold this year. Readers gave the appliance high marks for end-user transparency and ease of use. Authentication support was also rated highly by users of the product. Users noted Big-IP Edge Gateway has outstanding gateway functions and is easy to manage and support.
TECHTARGET: “Administrators use the GUI-based Visual Policy Editor, included in BIG-IP Edge Gateway, to define access policies based on device types or network types. These access policies are used by the device to check, authenticate and authorize users, in compliance with their organization’s policies.”
Version history
Last update:
‎07-Oct-2011 00:18
Updated by:
Contributors
