Technical Articles
F5 SMEs share good practice.
Graham_Alderso1
F5 Employee
F5 Employee
Learn how to use the F5 Advanced Web Application Firewall to protect your credentials. Identities are the keys to our applications and criminals can steal them right from the browser. DataSafe protects the credentials at the most vulnerable point.
See the entire AppSec Made Easy series.
Comments
Piotr_Bratkows3
Hello,
Very nice video. Could you tell me what's the name of the tool you are using for man in the browser?
Regards, Piotr
Graham_Alderso1
F5 Employee
F5 Employee
Piotr, it's a tool built internally and not made available to the public.
You can build your own pretty easily if you're adept at JavaScript and JQuery though, I'm just calling a .js file here with my shortcut, causing the same thing to happen as if it was embedded into the page with a script tag.
Version history
Last update:
‎09-May-2018 04:00
Updated by:
Contributors
