Matthew_Quill_3
Historic F5 Account
Problem this snippet solves:
An iApp that includes the iRule deployment instructions for the SiteMinder and F5 APM integration. This is a pretty powerful way to directly integrate the universal access capabilities of F5 APM with the Authorization functions of CA SiteMinder. We have had a number of joint customers looking for this direct integration.
Comments
F5Hovey_37123
Historic F5 Account
Update: This solution is no longer valid as the SecureAuth PDP product has been end-of-lifed.
Version history
Last update:
‎11-Mar-2015 14:59
Updated by:
Contributors
