Retrieve platform version using iControl Proxy (Java code sample)
Problem this snippet solves:
This Java client code sample uses the iControl Proxy to retrieve the platform version for each device managed by the referenced Enterprise Manager.
Code :
// Get EM iControl interface. iControl.Interfaces ic = new iControl.Interfaces(); ic.initialize(ipAddress, port, userName, password); // Get devices. String[] deviceList = iControl.ManagementEM.get_devices(); // Iterate through devices. for (int i=0; i < deviceList.length; i++) { // Get new context ID for each device (i.e. 'device session' use). String context = iControl.ManagementEM.get_context_id(); // Use this when setting up multiple connections to the same endpoint // with alternating proxy context IDs. //ic.setEndpoint(deviceList[i], port, "/iControl/iControlPortal.cgi?context_id=" + context); // Set device context for current device. iControl.ManagementEM.set_device_context(deviceList[i]); // Get remote device version. String version = iControl.SystemSystemInfo.get_version(); }
Published Mar 07, 2015
