Quick and dirty backup script for (v11) F5 LTM
Problem this snippet solves:
>SMTP Configuration
tmsh
modify /sys outbound-smtp mailhub yoursmtpserver.server.com:25
save /sys config
quit
> Execute privileges
chmod +x f5_backup.sh
>Cron job
configure in "crontab -e" or drop in /etc/cron.daily
How to use this snippet:
Uses SSH keys for authentication, here's a good how-to article on setting this up:
Code :
#!/bin/bash HOSTNAME=$(uname -n) DATE="$(date +%Y%m%d%H%M%S)" FILENAME="${HOSTNAME}${DATE}" function fail { echo "$@" | mail -vs "UCS backup failed $HOSTNAME" group@xyz.domain.com exit 1 } tmsh save sys ucs /var/local/ucs/config.ucs if [ ! -e /root/.ssh/id_rsa ]; then fail "Missing SSH Key" fi if [ ! -e /var/local/ucs/config.ucs ]; then fail "Missing configuration export" fi if ! scp -v -i /root/.ssh/id_rsa /var/local/ucs/config.ucs "user@xyz.domain.com:/configs/F5_backups/${FILENAME}.ucs"; then fail "Configuration upload failed" else echo "success" | mail -vs "UCS backup success $HOSTNAME" group@xyz.domain.com fi if ! ssh -i /root/.ssh/id_rsa user@xyz.domain.com find /configs/F5_backups/ -mtime +30 -exec rm '{}' \\\;;then echo "Backup cleanup failed" | fail fi exit 0
Tested this on version:
11.6Published May 22, 2017
