Python script to print report of VIPs, corresponding profiles, SSL profile cipher strings and full cipher list
Problem this snippet solves:
This script pulls a list of all clientssl and serverssl profiles and stores them in a dictionary. It then pulls a list of all the virtuals and reports the virtual's profiles... if any of those profiles are client or server ssl profiles, the cipher string is listed and then the entire cipher list is shown.
How to use this snippet:
Set the variables:
BIG_IP['mgmt_ip'] = '192.168.1.101'
BIG_IP['username'] = 'admin'
BIG_IP['password'] = 'admin'
and execute!
Code :
#!/usr/bin/env python3 import requests,json,urllib3 urllib3.disable_warnings(urllib3.exceptions.InsecureRequestWarning) def abort_script(reason): print('*** Aborting script execution! ***') if len(str(reason)) > 0: print('ERROR: ' + str(reason)) sys.exit(2) def icontrol_get(host,username,password,path): apiCall = requests.session() apiCall.headers.update({'Content-type':'application/json'}) apiCall.auth = (username,password) apiUri = 'https://' + host + '/mgmt/tm' + path try: apiResponse = apiCall.get(apiUri,verify=False) except requests.exceptions.RequestException as e: abort_script(str(e)) return(apiResponse.text) def icontrol_post(host,username,password,path,api_payload): apiCall = requests.session() apiCall.headers.update({'Content-type':'application/json'}) apiCall.auth = (username,password) apiUri = 'https://' + host + '/mgmt/tm' + path try: apiResponse = apiCall.post(apiUri,verify=False,data=json.dumps(api_payload)) except requests.exceptions.RequestException as e: abort_script(str(e)) return(apiResponse.text) BIG_IP = {} BIG_IP['mgmt_ip'] = '192.168.1.101' BIG_IP['username'] = 'admin' BIG_IP['password'] = 'admin' CLIENTSSL_PROFILE_CIPHERS = {} SERVERSSL_PROFILE_CIPHERS = {} VIPS = {} dictionary_entry = {} # Retrieve all SSL profiles api_response = icontrol_get(BIG_IP['mgmt_ip'],BIG_IP['username'],BIG_IP['password'],'/ltm/profile/client-ssl') api_response_dict = json.loads(api_response) clientssl_profile_list = api_response_dict['items'] for current_clientssl_profile in clientssl_profile_list: current_clientssl_profile_name = str(current_clientssl_profile['name']) current_clientssl_profile_cipherstring = str(current_clientssl_profile['ciphers']) print('Found Client SSL profile: ' + current_clientssl_profile_name) print(' -> Ciphers: ' + current_clientssl_profile_cipherstring) print(' -> Retreiving complete cipher list') api_payload = {"command":"run","utilCmdArgs":"-c 'tmm --serverciphers " + current_clientssl_profile_cipherstring + "'"} api_response = icontrol_post(BIG_IP['mgmt_ip'],BIG_IP['username'],BIG_IP['password'],'/util/bash',api_payload) api_response_dict = json.loads(api_response) current_clientssl_profile_cipherlist = api_response_dict['commandResult'] CLIENTSSL_PROFILE_CIPHERS[current_clientssl_profile_name] = {} CLIENTSSL_PROFILE_CIPHERS[current_clientssl_profile_name]['name'] = current_clientssl_profile_name CLIENTSSL_PROFILE_CIPHERS[current_clientssl_profile_name]['cipherstring'] = current_clientssl_profile_cipherstring CLIENTSSL_PROFILE_CIPHERS[current_clientssl_profile_name]['cipherlist'] = current_clientssl_profile_cipherlist api_response = icontrol_get(BIG_IP['mgmt_ip'],BIG_IP['username'],BIG_IP['password'],'/ltm/profile/server-ssl') api_response_dict = json.loads(api_response) serverssl_profile_list = api_response_dict['items'] for current_serverssl_profile in serverssl_profile_list: current_serverssl_profile_name = str(current_serverssl_profile['name']) current_serverssl_profile_cipherstring = str(current_serverssl_profile['ciphers']) print('Found Server SSL profile: ' + current_serverssl_profile_name) print(' -> Ciphers: ' + current_serverssl_profile_cipherstring) print(' -> Retreiving complete cipher list') api_payload = {"command":"run","utilCmdArgs":"-c 'tmm --serverciphers " + current_serverssl_profile_cipherstring + "'"} api_response = icontrol_post(BIG_IP['mgmt_ip'],BIG_IP['username'],BIG_IP['password'],'/util/bash',api_payload) api_response_dict = json.loads(api_response) current_serverssl_profile_cipherlist = api_response_dict['commandResult'] SERVERSSL_PROFILE_CIPHERS[current_serverssl_profile_name] = {} SERVERSSL_PROFILE_CIPHERS[current_serverssl_profile_name]['name'] = current_serverssl_profile_name SERVERSSL_PROFILE_CIPHERS[current_serverssl_profile_name]['cipherstring'] = current_serverssl_profile_cipherstring SERVERSSL_PROFILE_CIPHERS[current_serverssl_profile_name]['cipherlist'] = current_serverssl_profile_cipherlist # Retrieve all the VIPs api_response = icontrol_get(BIG_IP['mgmt_ip'],BIG_IP['username'],BIG_IP['password'],'/ltm/virtual') api_response_dict = json.loads(api_response) ltm_virtual_list = api_response_dict['items'] for current_virtual in ltm_virtual_list: print('************************************************************************************************************************') print('Virtual server found: ' + current_virtual['name']) print('************************************************************************************************************************') api_response = icontrol_get(BIG_IP['mgmt_ip'],BIG_IP['username'],BIG_IP['password'],'/ltm/virtual/' + current_virtual['name'] + '/profiles') api_response_dict = json.loads(api_response) current_virtual_profiles = api_response_dict['items'] for current_virtual_profile in current_virtual_profiles: print(' -> Profile found: ' + current_virtual_profile['name'] + ' (Context: ' + current_virtual_profile['context'] + ')') if current_virtual_profile['context'] == 'clientside' and current_virtual_profile['name'] in CLIENTSSL_PROFILE_CIPHERS: print(' -> Cipher string: ' + CLIENTSSL_PROFILE_CIPHERS[current_virtual_profile['name']]['cipherstring']) print(' -> Complete cipher list: \n' + CLIENTSSL_PROFILE_CIPHERS[current_virtual_profile['name']]['cipherlist']) elif current_virtual_profile['context'] == 'serverside' and current_virtual_profile['name'] in SERVERSSL_PROFILE_CIPHERS: print(' -> Cipher string: ' + SERVERSSL_PROFILE_CIPHERS[current_virtual_profile['name']]['cipherstring']) print(' -> Complete cipher list: \n' + SERVERSSL_PROFILE_CIPHERS[current_virtual_profile['name']]['cipherlist']) else: print(' -> Non-SSL Profile') print('*************************') print('* END OF VIRTUAL SERVER *') print('*************************')
Tested this on version:
12.1Published Aug 13, 2019
