python bigsuds - Get Orphaned iRules
Problem this snippet solves:
This python bigsuds script will get a list of all iRules that are not associated with a virtual server (orphaned).
How to use this snippet:
orphanedrules.py <hostname> <username>
Script will prompt for password.
Script
orphanedrules.py
Code :
#!/usr/bin/env python
__author__ = 'buzzsurfr'
__version__ = '0.1'
def get_orphaned_rules(obj, recursive = True):
Gets a list of orphaned rules.
Prototype
String [] get_orphaned_rules(
BIGIP.bigip obj,
bool recursive = True
Parameters
obj of type BIGIP.bigip contains the established connection.
recursive of type boolean indicates whether to perform a recursive search throughout the entire configuration.  Defaults to True.
Return Type
String [] containing the list of all orphaned rules.
#  Get current values to override for search
active_folder = obj.System.Session.get_active_folder()
recursive_query_state = obj.System.Session.get_recursive_query_state()
#  Enable fully-recursive search
if recursive:
obj.System.Session.set_active_folder('/')
obj.System.Session.set_recursive_query_state("STATE_ENABLED")
#  Get list of iRules
rules = obj.LocalLB.Rule.get_list()
#  Create starting list of orphaned iRules.  These will be removed from
#  list as they are found to be in use.
orphaned_rules = rules
#  Get list of all iRules associated on virtual servers
vs_rules = obj.LocalLB.VirtualServer.get_rule(obj.LocalLB.VirtualServer.get_list())
#  Check each virtual server for iRules and remove from orphaned if exists
for virtual_server in vs_rules:
for rule in virtual_server:
if rule['rule_name'] in rules:
#  If found, remove from orphaned_rules
orphaned_rules.remove(rule['rule_name'])
#  Reset values overridden for search
if recursive:
obj.System.Session.set_active_folder(active_folder)
obj.System.Session.set_recursive_query_state(recursive_query_state)
return orphaned_rules
#  Instance Mode (Run as script)
if __name__ == "__main__":
#  Standard Library
import sys
#  Related Third-Party
import getpass
#  Local Application/Library Specific
import bigsuds
if len(sys.argv) < 3:
print "\n\n\tUsage: %s ip_address username" % sys.argv[0]
sys.exit()
#  Get password from CLI
userpass = getpass.getpass()
#  Connect to BIG-IP
try:
bigconn = bigsuds.BIGIP(
hostname = sys.argv[1],
username = sys.argv[2],
password = userpass
except Exception as e:
print e
orphans = get_orphaned_rules(bigconn)
print "Orphaned iRules"
for orphan in orphans:
print "\t" + orphan
Tested this on version:
11.5
Updated Jun 06, 2023
Version 2.0
Was this article helpful?
