JackofallTrades
Historic F5 Account
Problem this snippet solves:
This pyControl script creates a Datacenter. It checks to makesure the ip addres of the bigip is a valid IP address. This version of the script will allow you to pass command line arguments to the script.
Code :
#This Script creates a DC .
import pycontrol.pyControl as pyControl
import sys
import re
#check to see if the right number of arguments are present
nargs = len(sys.argv)
if nargs < 7:
print "Usage: create_dc.py GTM_ip_addr username password DC_name DC_location contact"
        sys.exit()
#check to makesure the ip addres is valid
ip_str = sys.argv[1]
def checkip(ip_str):
   pattern = r"\b(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\b"
   if re.match(pattern, ip_str):
      return True
   else:
     print checkip(ip_str)
#Create the BigIP object
b = pyControl.BIGIP(hostname   = sys.argv[1],
    username   = sys.argv[2],
    password   = sys.argv[3],
    wsdl_files = ['GlobalLB.DataCenter']
#Create a DC
d = b.GlobalLB_DataCenter
try:
d.create( data_centers = [{'name' : sys.argv[4],
 'location': sys.argv[5],
 'contact' : sys.argv[6]}])
print "DATA CENTER Successfully created."
except: print "DC creation error. Check log."
# Enable the DC
try:
d.set_enabled_state( data_centers = [sys.argv[4]],
states = ['1']
print "DATA CENTER Successfully enabled."
except: print "DC enable error. Check log."
Version history
Last update:
‎09-Mar-2015 12:25
Updated by:
Contributors
