JackofallTrades
Historic F5 Account
Problem this snippet solves:
This script creates a pool and adds a VS for GTM
Code :
####Creates a pool and more....
import pycontrol.pyControl as pyControl
b = pyControl.BIGIP(hostname   = '10.10.10.10',
                    username   = 'admin',
                    password   = 'admin',
                    wsdl_files = ['GlobalLB.Pool']
d = b.GlobalLB_Pool
##Creates the Pool and this script adds two virtual servers
##This secton also specifys the LB_METHOD
try:
        d.create(
pool_names = ['pypool1'],
lb_methods = ['LB_METHOD_GLOBAL_AVAILABILITY'],
                           members = [[{'member': {'address': '10.10.10.100', 'port': 80}, 'order': 0},
                         {'member': {'address': '10.10.10.101', 'port': 80}, 'order': 1}]],
        print "Pool was created"
except:
print "Pool Creation failed. Check log."
###############This section creates the alternate LB_Method
try:
d.set_alternate_lb_method(
lb_methods = ['LB_METHOD_STATIC_PERSIST']
        print "Alternate LB_method applied"
except: print "Alternate LB_method applied failed"
###################Creates Fallback IP
try:
d.set_fallback_ip(
ips  = ['192.168.1.1']
print "Fallback ip was applied "
except: print "Fallback ip applied failed"
#Creates Monitor associated with Pool
try:
 d.set_monitor_association (
monitor_associations = [{'monitor_rule': {'monitor_templates': ['http'],
                                         'quorum': 0,
                                         'type': 'MONITOR_RULE_TYPE_SINGLE'},
                                         'pool_name': 'pypool1'}]
 print "Monitor was applied to pool"
except:      print "Monitor failed to be applied. Check log.
Version history
Last update:
‎09-Mar-2015 12:25
Updated by:
Contributors
