Problem this snippet solves:
This example illustrates how to use the Folder methods to build a console shell allowing you to navigate and manage system Folders on BIG-IP v11 and above.
Code :
#----------------------------------------------------------------------------\n# The contents of this file are subject to the \"END USER LICENSE AGREEMENT \n# FOR F5 Software Development Kit for iControl\"; you may not use this file \n# except in compliance with the License. The License is included in the \n# iControl Software Development Kit.\n#\n# Software distributed under the License is distributed on an \"AS IS\"\n# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See\n# the License for the specific language governing rights and limitations\n# under the License.\n#\n# The Original Code is iControl Code and related documentation\n# distributed by F5.\n#\n# The Initial Developer of the Original Code is F5 Networks, Inc. \n# Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2011 \n# F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered \n# trademark of F5 Networks, Inc.\n#\n# Alternatively, the contents of this file may be used under the terms\n# of the GNU General Public License (the \"GPL\"), in which case the\n# provisions of GPL are applicable instead of those above. If you wish\n# to allow use of your version of this file only under the terms of the\n# GPL and not to allow others to use your version of this file under the\n# License, indicate your decision by deleting the provisions above and\n# replace them with the notice and other provisions required by the GPL.\n# If you do not delete the provisions above, a recipient may use your\n# version of this file under either the License or the GPL.\n#----------------------------------------------------------------------------\nparam (\n $bigip = $null,\n $uid = $null,\n $pwd = $null\n)\n\nSet-PSDebug -strict;\n\n# Global Script variables\n$script:DEBUG = $false;\n$script:FOLDER = $null;\n$script:RECURSE = \"STATE_DISABLED\";\n\n#-------------------------------------------------------------------------\n# function usage\n#-------------------------------------------------------------------------\nfunction usage()\n{\n Write-Host \"Usage: ManagementFolder.ps1 host uid pwd\";\n exit;\n}\n\n#----------------------------------------------------------------------------\nfunction Debug-Message()\n#----------------------------------------------------------------------------\n{\n param($msg);\n \n if ( $script:DEBUG )\n {\n Write-Host \"DEBUG > $msg\";\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Get-CurrentFolder()\n#----------------------------------------------------------------------------\n{\n param([switch]$Force = $false);\n \n if ( ($($script:FOLDER) -eq $null) -or ($Force) )\n {\n $folder = (Get-F5.iControl).SystemSession.get_active_folder();\n }\n else\n {\n $folder = $script:FOLDER;\n }\n $folder;\n}\n\n#----------------------------------------------------------------------------\nfunction Get-ChildFolders()\n#----------------------------------------------------------------------------\n{\n param([switch]$Recurse = $false, [switch]$Long = $false);\n\n $Long = $true;\n if ( $Recurse )\n {\n $oldstate = (Get-F5.iControl).SystemSession.get_recursive_query_state();\n (Get-F5.iControl).SystemSession.set_recursive_query_state(\"STATE_ENABLED\");\n }\n $folders = (Get-F5.iControl).ManagementFolder.get_list();\n if ( $Recurse -and ($oldstate -ne \"STATE_ENABLED\") )\n {\n (Get-F5.iControl).SystemSession.set_recursive_query_state($oldstate);\n }\n \n $descriptions = (Get-F5.iControl).ManagementFolder.get_description($folders);\n $groups = (Get-F5.iControl).ManagementFolder.get_device_group($folders);\n \n $curfolder = Get-CurrentFolder;\n if ( $curfolder -eq \"/\" ) { $curfolder = \"ZZZZZZZZ\"; }\n \n for($i=0;$i-lt$folders.length;$i++)\n {\n if ( $Long )\n {\n $o = 1 | select \"Folder\", \"Description\", \"DeviceGroup\";\n $o.Folder = $folders[$i].Replace($curfolder, \"\");\n $o.Description = $descriptions[$i];\n $o.DeviceGroup = $groups[$i];\n }\n else\n {\n $o = 1 | select \"Folder\";\n $o.Folder = $folders[$i].Replace($curfolder, \"\");\n }\n $o;\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Change-Folder()\n#----------------------------------------------------------------------------\n{\n param($folder);\n \n Debug-Message \"Setting active folder to '$folder'\";\n if ( $folder -eq \"..\" )\n {\n Move-Up;\n }\n else\n {\n (Get-F5.iControl).SystemSession.set_active_folder($folder);\n }\n $f = Get-CurrentFolder -Force;\n}\n\n#----------------------------------------------------------------------------\nfunction Move-Up()\n#----------------------------------------------------------------------------\n{\n $folder = Get-CurrentFolder;\n $parent = (Split-Path $folder).Replace('\\', '/');\n if ( $parent.Length -gt 0 )\n {\n Debug-Message \"Setting active folder to '$parent'\";\n (Get-F5.iControl).SystemSession.set_active_folder($parent);\n }\n $f = Get-CurrentFolder -Force;\n}\n\n#----------------------------------------------------------------------------\nfunction Create-Folder()\n#----------------------------------------------------------------------------\n{\n param($folder);\n Debug-Message \"Creating folder '$folder'\";\n (Get-F5.iControl).ManagementFolder.create($folder);\n Write-Host \"Folder '$folder' successfully created!\";\n}\n\n#----------------------------------------------------------------------------\nfunction Remove-Folder()\n#----------------------------------------------------------------------------\n{\n param($folder);\n Debug-Message \"Removing folder '$folder'\";\n (Get-F5.iControl).ManagementFolder.delete_folder($folder);\n Write-Host \"Folder '$folder' successfully removed!\";\n}\n\n#----------------------------------------------------------------------------\nfunction Set-FolderDescription()\n#----------------------------------------------------------------------------\n{\n param($cmd);\n $tokens = $cmd.Split(\" \");\n if ( $tokens.Length -eq 1 )\n {\n $f = $cmd;\n $d = \"\";\n Debug-Message \"Setting folder '$folder' description to '$d'\";\n (Get-F5.iControl).ManagementFolder.set_description($f, $d);\n Get-FolderDescription $f;\n }\n elseif ( $tokens.Length -gt 1 )\n {\n # folder description goes here\n $f = $tokens[0];\n $d = $tokens[1];\n for($i=2; $i-lt$tokens.Length; $i++)\n {\n $d += \" \";\n $d += $tokens[$i];\n }\n Debug-Message \"Setting folder '$f' description to '$d'\";\n (Get-F5.iControl).ManagementFolder.set_description($f, $d);\n Get-FolderDescription $f;\n }\n else\n {\n Show-Help;\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Get-FolderDescription()\n#----------------------------------------------------------------------------\n{\n param($folder);\n Debug-Message \"Retrieving folder description for '$folder'\";\n $descriptions = (Get-F5.iControl).ManagementFolder.get_description($folder);\n $descriptions[0];\n}\n\n#----------------------------------------------------------------------------\nfunction Get-RecursiveState()\n#----------------------------------------------------------------------------\n{\n $oldState = (Get-F5.iControl).SystemSession.get_recursive_query_state();\n $script:RECURSE = $oldState;\n $oldState;\n}\n\n#----------------------------------------------------------------------------\nfunction Set-RecursiveState()\n#----------------------------------------------------------------------------\n{\n param($state = $null);\n \n $newState = \"STATE_DISABLED\";\n if ( $state -eq $null )\n {\n # toggle\n $oldState = (Get-F5.iControl).SystemSession.get_recursive_query_state();\n if ( $oldState -eq \"STATE_DISABLED\" )\n {\n $newState = \"STATE_ENABLED\";\n }\n }\n else\n {\n # set\n if ( $state.ToLower().Contains(\"enable\") )\n {\n $newState = \"STATE_ENABLED\";\n }\n }\n $script:RECURSE = $newState;\n (Get-F5.iControl).SystemSession.set_recursive_query_state($newState);\n Write-Host \"Recursive State set to '$newState'\";\n}\n\n#----------------------------------------------------------------------------\nfunction Execute-Command()\n#----------------------------------------------------------------------------\n{\n param($cmd);\n \n $fullcmd = $cmd;\n if ( -not $fullcmd.ToLower().StartsWith(\"(get-f5.icontrol).\") )\n {\n $fullcmd = \"(Get-F5.iControl).$cmd\";\n }\n \n Debug-Message \"Executing command '$fullcmd'\";\n Invoke-Expression $fullcmd;\n}\n\n#----------------------------------------------------------------------------\nfunction Show-Help()\n#----------------------------------------------------------------------------\n{\n $indent = \" \"*5;\n \n Write-Host @\"\n$indent ====================================================================\n$indent iControl Folder Shell\n$indent ====================================================================\n\n$indent Commands\n$indent --------\n$indent cd folder - change active folder\n$indent d - toggle script debugging\n$indent dir,ls - List child folders\n$indent gd folder - Get folder description\n$indent h - Show this help\n$indent ls -l - List child folders and their properties\n$indent ls -r - List recursive listing of child folders\n$indent ls -lr - List recursive listing of child folders\n$indent and their properties\n$indent md,mkdir - create folder\n$indent pwd - Get current folder\n$indent r enable|disable - Set the recursive state. Omitting a \n$indent state value will toggle it.\n$indent rd,rmdir - remove folder\n$indent sd folder desc - Set folder description\n$indent q - quit the shell\n$indent ! command - execute the iControl command\n$indent $INTERFACE.call - execute the iControl command\n$indent .. - Move to parent folder\n\"@;\n}\n\n#----------------------------------------------------------------------------\nfunction Get-Args()\n#----------------------------------------------------------------------------\n{\n param($cmd);\n $tokens = $cmd.Trim().Split(\" \");\n $cmd = $tokens[0];\n $args = $tokens[1];\n for($i=2; $i-lt$tokens.Length;$i++)\n {\n $args += \" \";\n $args += $tokens[$i];\n }\n $args;\n}\n\n#----------------------------------------------------------------------------\nfunction Process-Input()\n#----------------------------------------------------------------------------\n{\n param($i);\n Debug-Message \"< $($MyInvocation.MyCommand.Name) '$i' >\";\n if ( $i.Length -gt 0 )\n {\n Debug-Message \"CommandLine: '$i'...\";\n switch -Wildcard ($i.Trim().ToLower())\n {\n \"\" { break; }\n \"cd *\" { Change-Folder (Get-Args $i); }\n \"cd\" { Get-CurrentFolder; }\n \"d\" { $script:DEBUG = -not $script:DEBUG; }\n \"dir\" { Get-ChildFolders | Sort-Object Folder; }\n \"gd *\" { Get-FolderDescription (Get-Args $i); }\n \"h\" { Show-Help; }\n \"ls\" { Get-ChildFolders | Sort-Object Folder; }\n \"ls -l\" { Get-ChildFolders -Long | Sort-Object Folder; }\n \"ls -lr\" { Get-ChildFolders -Recurse -Long | Sort-Object Folder; }\n \"ls -r\" { Get-ChildFolders -Recurse | Sort-Object Folder; }\n \"md *\" { Create-Folder (Get-Args $i); }\n \"mkdir *\" { Create-Folder (Get-Args $i); }\n \"pwd\" { Get-CurrentFolder; }\n \"r\" { Set-RecursiveState; }\n \"r *\" { Set-RecursiveState (Get-Args $i); }\n \"rd *\" { Remove-Folder (Get-Args $i); }\n \"rmdir *\" { Remove-Folder (Get-Args $i); }\n \"sd *\" { Set-FolderDescription (Get-Args $i); }\n \"q\" { exit; }\n \"! *\" { Execute-Command (Get-Args $i); }\n \"$*\" { Execute-Command $i.SubString(1); }\n \"..\" { Move-Up; }\n default { Show-Help; }\n }\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Get-Prompt()\n#----------------------------------------------------------------------------\n{\n # [(r)/Common]\n \n $prefix = \"\";\n if ( $script:DEBUG -or ($script:RECURSE -eq \"STATE_ENABLED\") )\n {\n $prefix = \"(\";\n if ( $script:DEBUG )\n {\n $prefix += \"d\";\n }\n if ( $script:RECURSE -eq \"STATE_ENABLED\" )\n {\n if ( $prefix -ne \"(\" ) { $prefix += \",\"; }\n $prefix += \"r\";\n }\n $prefix += \")\";\n }\n \"[${prefix}$(Get-CurrentFolder)] \";\n \n #if ( $script:DEBUG ) { $prefix = \"D:\"; }\n #$prompt = \"[${prefix}$(Get-CurrentFolder)] \";\n}\n\n#----------------------------------------------------------------------------\nfunction Do-Initialize()\n#----------------------------------------------------------------------------\n{\n if ( (Get-PSSnapin | Where-Object { $_.Name -eq \"iControlSnapIn\"}) -eq $null )\n {\n Add-PSSnapIn iControlSnapIn\n }\n $success = Initialize-F5.iControl -HostName $bigip -Username $uid -Password $pwd;\n \n return $success;\n}\n\n#-------------------------------------------------------------------------\n# Main Application Logic\n#-------------------------------------------------------------------------\nif ( ($bigip -eq $null) -or ($uid -eq $null) -or ($pwd -eq $null) )\n{\n usage;\n}\n\nif ( Do-Initialize )\n{\n $s = Get-RecursiveState;\n while(1)\n {\n $prompt = Get-Prompt;\n # Not using Read-Host here so we can support responses starting with !\n $host.UI.Write($prompt);\n $i = $host.UI.ReadLine().Trim();\n Process-Input $i;\n }\n}\nelse\n{\n Write-Error \"ERROR: iControl subsystem not initialized\"\n}","body@stringLength":"13613","rawBody":"
Code :
#----------------------------------------------------------------------------\n# The contents of this file are subject to the \"END USER LICENSE AGREEMENT \n# FOR F5 Software Development Kit for iControl\"; you may not use this file \n# except in compliance with the License. The License is included in the \n# iControl Software Development Kit.\n#\n# Software distributed under the License is distributed on an \"AS IS\"\n# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See\n# the License for the specific language governing rights and limitations\n# under the License.\n#\n# The Original Code is iControl Code and related documentation\n# distributed by F5.\n#\n# The Initial Developer of the Original Code is F5 Networks, Inc. \n# Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2011 \n# F5 Networks, Inc. All Rights Reserved. iControl (TM) is a registered \n# trademark of F5 Networks, Inc.\n#\n# Alternatively, the contents of this file may be used under the terms\n# of the GNU General Public License (the \"GPL\"), in which case the\n# provisions of GPL are applicable instead of those above. If you wish\n# to allow use of your version of this file only under the terms of the\n# GPL and not to allow others to use your version of this file under the\n# License, indicate your decision by deleting the provisions above and\n# replace them with the notice and other provisions required by the GPL.\n# If you do not delete the provisions above, a recipient may use your\n# version of this file under either the License or the GPL.\n#----------------------------------------------------------------------------\nparam (\n $bigip = $null,\n $uid = $null,\n $pwd = $null\n)\n\nSet-PSDebug -strict;\n\n# Global Script variables\n$script:DEBUG = $false;\n$script:FOLDER = $null;\n$script:RECURSE = \"STATE_DISABLED\";\n\n#-------------------------------------------------------------------------\n# function usage\n#-------------------------------------------------------------------------\nfunction usage()\n{\n Write-Host \"Usage: ManagementFolder.ps1 host uid pwd\";\n exit;\n}\n\n#----------------------------------------------------------------------------\nfunction Debug-Message()\n#----------------------------------------------------------------------------\n{\n param($msg);\n \n if ( $script:DEBUG )\n {\n Write-Host \"DEBUG > $msg\";\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Get-CurrentFolder()\n#----------------------------------------------------------------------------\n{\n param([switch]$Force = $false);\n \n if ( ($($script:FOLDER) -eq $null) -or ($Force) )\n {\n $folder = (Get-F5.iControl).SystemSession.get_active_folder();\n }\n else\n {\n $folder = $script:FOLDER;\n }\n $folder;\n}\n\n#----------------------------------------------------------------------------\nfunction Get-ChildFolders()\n#----------------------------------------------------------------------------\n{\n param([switch]$Recurse = $false, [switch]$Long = $false);\n\n $Long = $true;\n if ( $Recurse )\n {\n $oldstate = (Get-F5.iControl).SystemSession.get_recursive_query_state();\n (Get-F5.iControl).SystemSession.set_recursive_query_state(\"STATE_ENABLED\");\n }\n $folders = (Get-F5.iControl).ManagementFolder.get_list();\n if ( $Recurse -and ($oldstate -ne \"STATE_ENABLED\") )\n {\n (Get-F5.iControl).SystemSession.set_recursive_query_state($oldstate);\n }\n \n $descriptions = (Get-F5.iControl).ManagementFolder.get_description($folders);\n $groups = (Get-F5.iControl).ManagementFolder.get_device_group($folders);\n \n $curfolder = Get-CurrentFolder;\n if ( $curfolder -eq \"/\" ) { $curfolder = \"ZZZZZZZZ\"; }\n \n for($i=0;$i-lt$folders.length;$i++)\n {\n if ( $Long )\n {\n $o = 1 | select \"Folder\", \"Description\", \"DeviceGroup\";\n $o.Folder = $folders[$i].Replace($curfolder, \"\");\n $o.Description = $descriptions[$i];\n $o.DeviceGroup = $groups[$i];\n }\n else\n {\n $o = 1 | select \"Folder\";\n $o.Folder = $folders[$i].Replace($curfolder, \"\");\n }\n $o;\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Change-Folder()\n#----------------------------------------------------------------------------\n{\n param($folder);\n \n Debug-Message \"Setting active folder to '$folder'\";\n if ( $folder -eq \"..\" )\n {\n Move-Up;\n }\n else\n {\n (Get-F5.iControl).SystemSession.set_active_folder($folder);\n }\n $f = Get-CurrentFolder -Force;\n}\n\n#----------------------------------------------------------------------------\nfunction Move-Up()\n#----------------------------------------------------------------------------\n{\n $folder = Get-CurrentFolder;\n $parent = (Split-Path $folder).Replace('\\', '/');\n if ( $parent.Length -gt 0 )\n {\n Debug-Message \"Setting active folder to '$parent'\";\n (Get-F5.iControl).SystemSession.set_active_folder($parent);\n }\n $f = Get-CurrentFolder -Force;\n}\n\n#----------------------------------------------------------------------------\nfunction Create-Folder()\n#----------------------------------------------------------------------------\n{\n param($folder);\n Debug-Message \"Creating folder '$folder'\";\n (Get-F5.iControl).ManagementFolder.create($folder);\n Write-Host \"Folder '$folder' successfully created!\";\n}\n\n#----------------------------------------------------------------------------\nfunction Remove-Folder()\n#----------------------------------------------------------------------------\n{\n param($folder);\n Debug-Message \"Removing folder '$folder'\";\n (Get-F5.iControl).ManagementFolder.delete_folder($folder);\n Write-Host \"Folder '$folder' successfully removed!\";\n}\n\n#----------------------------------------------------------------------------\nfunction Set-FolderDescription()\n#----------------------------------------------------------------------------\n{\n param($cmd);\n $tokens = $cmd.Split(\" \");\n if ( $tokens.Length -eq 1 )\n {\n $f = $cmd;\n $d = \"\";\n Debug-Message \"Setting folder '$folder' description to '$d'\";\n (Get-F5.iControl).ManagementFolder.set_description($f, $d);\n Get-FolderDescription $f;\n }\n elseif ( $tokens.Length -gt 1 )\n {\n # folder description goes here\n $f = $tokens[0];\n $d = $tokens[1];\n for($i=2; $i-lt$tokens.Length; $i++)\n {\n $d += \" \";\n $d += $tokens[$i];\n }\n Debug-Message \"Setting folder '$f' description to '$d'\";\n (Get-F5.iControl).ManagementFolder.set_description($f, $d);\n Get-FolderDescription $f;\n }\n else\n {\n Show-Help;\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Get-FolderDescription()\n#----------------------------------------------------------------------------\n{\n param($folder);\n Debug-Message \"Retrieving folder description for '$folder'\";\n $descriptions = (Get-F5.iControl).ManagementFolder.get_description($folder);\n $descriptions[0];\n}\n\n#----------------------------------------------------------------------------\nfunction Get-RecursiveState()\n#----------------------------------------------------------------------------\n{\n $oldState = (Get-F5.iControl).SystemSession.get_recursive_query_state();\n $script:RECURSE = $oldState;\n $oldState;\n}\n\n#----------------------------------------------------------------------------\nfunction Set-RecursiveState()\n#----------------------------------------------------------------------------\n{\n param($state = $null);\n \n $newState = \"STATE_DISABLED\";\n if ( $state -eq $null )\n {\n # toggle\n $oldState = (Get-F5.iControl).SystemSession.get_recursive_query_state();\n if ( $oldState -eq \"STATE_DISABLED\" )\n {\n $newState = \"STATE_ENABLED\";\n }\n }\n else\n {\n # set\n if ( $state.ToLower().Contains(\"enable\") )\n {\n $newState = \"STATE_ENABLED\";\n }\n }\n $script:RECURSE = $newState;\n (Get-F5.iControl).SystemSession.set_recursive_query_state($newState);\n Write-Host \"Recursive State set to '$newState'\";\n}\n\n#----------------------------------------------------------------------------\nfunction Execute-Command()\n#----------------------------------------------------------------------------\n{\n param($cmd);\n \n $fullcmd = $cmd;\n if ( -not $fullcmd.ToLower().StartsWith(\"(get-f5.icontrol).\") )\n {\n $fullcmd = \"(Get-F5.iControl).$cmd\";\n }\n \n Debug-Message \"Executing command '$fullcmd'\";\n Invoke-Expression $fullcmd;\n}\n\n#----------------------------------------------------------------------------\nfunction Show-Help()\n#----------------------------------------------------------------------------\n{\n $indent = \" \"*5;\n \n Write-Host @\"\n$indent ====================================================================\n$indent iControl Folder Shell\n$indent ====================================================================\n\n$indent Commands\n$indent --------\n$indent cd folder - change active folder\n$indent d - toggle script debugging\n$indent dir,ls - List child folders\n$indent gd folder - Get folder description\n$indent h - Show this help\n$indent ls -l - List child folders and their properties\n$indent ls -r - List recursive listing of child folders\n$indent ls -lr - List recursive listing of child folders\n$indent and their properties\n$indent md,mkdir - create folder\n$indent pwd - Get current folder\n$indent r enable|disable - Set the recursive state. Omitting a \n$indent state value will toggle it.\n$indent rd,rmdir - remove folder\n$indent sd folder desc - Set folder description\n$indent q - quit the shell\n$indent ! command - execute the iControl command\n$indent $INTERFACE.call - execute the iControl command\n$indent .. - Move to parent folder\n\"@;\n}\n\n#----------------------------------------------------------------------------\nfunction Get-Args()\n#----------------------------------------------------------------------------\n{\n param($cmd);\n $tokens = $cmd.Trim().Split(\" \");\n $cmd = $tokens[0];\n $args = $tokens[1];\n for($i=2; $i-lt$tokens.Length;$i++)\n {\n $args += \" \";\n $args += $tokens[$i];\n }\n $args;\n}\n\n#----------------------------------------------------------------------------\nfunction Process-Input()\n#----------------------------------------------------------------------------\n{\n param($i);\n Debug-Message \"< $($MyInvocation.MyCommand.Name) '$i' >\";\n if ( $i.Length -gt 0 )\n {\n Debug-Message \"CommandLine: '$i'...\";\n switch -Wildcard ($i.Trim().ToLower())\n {\n \"\" { break; }\n \"cd *\" { Change-Folder (Get-Args $i); }\n \"cd\" { Get-CurrentFolder; }\n \"d\" { $script:DEBUG = -not $script:DEBUG; }\n \"dir\" { Get-ChildFolders | Sort-Object Folder; }\n \"gd *\" { Get-FolderDescription (Get-Args $i); }\n \"h\" { Show-Help; }\n \"ls\" { Get-ChildFolders | Sort-Object Folder; }\n \"ls -l\" { Get-ChildFolders -Long | Sort-Object Folder; }\n \"ls -lr\" { Get-ChildFolders -Recurse -Long | Sort-Object Folder; }\n \"ls -r\" { Get-ChildFolders -Recurse | Sort-Object Folder; }\n \"md *\" { Create-Folder (Get-Args $i); }\n \"mkdir *\" { Create-Folder (Get-Args $i); }\n \"pwd\" { Get-CurrentFolder; }\n \"r\" { Set-RecursiveState; }\n \"r *\" { Set-RecursiveState (Get-Args $i); }\n \"rd *\" { Remove-Folder (Get-Args $i); }\n \"rmdir *\" { Remove-Folder (Get-Args $i); }\n \"sd *\" { Set-FolderDescription (Get-Args $i); }\n \"q\" { exit; }\n \"! *\" { Execute-Command (Get-Args $i); }\n \"$*\" { Execute-Command $i.SubString(1); }\n \"..\" { Move-Up; }\n default { Show-Help; }\n }\n }\n}\n\n#----------------------------------------------------------------------------\nfunction Get-Prompt()\n#----------------------------------------------------------------------------\n{\n # [(r)/Common]\n \n $prefix = \"\";\n if ( $script:DEBUG -or ($script:RECURSE -eq \"STATE_ENABLED\") )\n {\n $prefix = \"(\";\n if ( $script:DEBUG )\n {\n $prefix += \"d\";\n }\n if ( $script:RECURSE -eq \"STATE_ENABLED\" )\n {\n if ( $prefix -ne \"(\" ) { $prefix += \",\"; }\n $prefix += \"r\";\n }\n $prefix += \")\";\n }\n \"[${prefix}$(Get-CurrentFolder)] \";\n \n #if ( $script:DEBUG ) { $prefix = \"D:\"; }\n #$prompt = \"[${prefix}$(Get-CurrentFolder)] \";\n}\n\n#----------------------------------------------------------------------------\nfunction Do-Initialize()\n#----------------------------------------------------------------------------\n{\n if ( (Get-PSSnapin | Where-Object { $_.Name -eq \"iControlSnapIn\"}) -eq $null )\n {\n Add-PSSnapIn iControlSnapIn\n }\n $success = Initialize-F5.iControl -HostName $bigip -Username $uid -Password $pwd;\n \n return $success;\n}\n\n#-------------------------------------------------------------------------\n# Main Application Logic\n#-------------------------------------------------------------------------\nif ( ($bigip -eq $null) -or ($uid -eq $null) -or ($pwd -eq $null) )\n{\n usage;\n}\n\nif ( Do-Initialize )\n{\n $s = Get-RecursiveState;\n while(1)\n {\n $prompt = Get-Prompt;\n # Not using Read-Host here so we can support responses starting with !\n $host.UI.Write($prompt);\n $i = $host.UI.ReadLine().Trim();\n Process-Input $i;\n }\n}\nelse\n{\n Write-Error \"ERROR: iControl subsystem not initialized\"\n}","kudosSumWeight":0,"postTime":"2015-03-09T11:33:57.000-07:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:devops","text":"devops","time":"2011-10-19T17:50:55.000-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDI","node":{"__typename":"Tag","id":"tag:iControl","text":"iControl","time":"2022-01-24T02:29:45.068-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuNHwyLjF8b3wxMHxfTlZffDM","node":{"__typename":"Tag","id":"tag:microsoft powershell with icontrol","text":"microsoft powershell with icontrol","time":"2022-01-24T02:29:45.066-08:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":6,"rawTeaser":"","introduction":"","currentRevision":{"__ref":"Revision:revision:278096_1"},"latestVersion":{"__typename":"FriendlyVersion","major":"1","minor":"0"},"metrics":{"__typename":"MessageMetrics","views":215},"read":false,"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"placeholder":false,"originalMessageForPlaceholder":null,"contributors":{"__typename":"UserConnection","edges":[]},"nonCoAuthorContributors":{"__typename":"UserConnection","edges":[]},"coAuthors":{"__typename":"UserConnection","edges":[{"__typename":"UserEdge","node":{"__ref":"User:user:131293"}}]},"tkbMessagePolicies":{"__typename":"TkbMessagePolicies","canDoAuthoringActionsOnTkb":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.tkb.policy_can_do_authoring_action.accessDenied","key":"error.lithium.policies.tkb.policy_can_do_authoring_action.accessDenied","args":[]}}},"archivalData":null,"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"customFields":[],"revisions({\"constraints\":{\"isPublished\":{\"eq\":true}}})":{"__typename":"RevisionConnection","totalCount":1}},"Conversation:conversation:278096":{"__typename":"Conversation","id":"conversation:278096","solved":false,"topic":{"__ref":"TkbTopicMessage:message:278096"},"lastPostingActivityTime":"2015-03-09T11:33:57.000-07:00","lastPostTime":"2015-03-09T11:33:57.000-07:00","unreadReplyCount":0,"isSubscribed":false},"ModerationData:moderation_data:278096":{"__typename":"ModerationData","id":"moderation_data:278096","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:278096_1":{"__typename":"Revision","id":"revision:278096_1","lastEditTime":"2015-03-09T11:33:57.000-07:00"},"CachedAsset:theme:customTheme1-1751560861348":{"__typename":"CachedAsset","id":"theme:customTheme1-1751560861348","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"android-chrome-512x512-1748534255255.png","imageLastModified":"1748534256856","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"F5-devCentral-HR-color-reverse-1750868999153.png","imageLastModified":"1750869001512","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"fluid","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_PAGE_CONTENT","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"5px","borderRadius":"5px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"14px","paddingXHero":"42px","fontStyle":"NORMAL","fontWeight":"500","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"#0072B0","primaryBgHoverColor":"hsl(201.10000000000002, 100%, 29.3%)","primaryBgActiveColor":"hsl(201.10000000000002, 100%, 24.2%)","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px #0072B0, 0 0 0 4px rgba(0, 114, 176, 0.2)","secondaryTextColor":"var(--lia-bs-white)","secondaryTextHoverColor":"var(--lia-bs-white)","secondaryTextActiveColor":"var(--lia-bs-white)","secondaryBgColor":"#0072B0","secondaryBgHoverColor":"hsl(201.10000000000002, 100%, 29.3%)","secondaryBgActiveColor":"hsl(201.10000000000002, 100%, 24.2%)","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px #0072B0, 0 0 0 4px rgba(0, 114, 176, 0.2)","tertiaryTextColor":"#0072B0","tertiaryTextHoverColor":"hsl(201.10000000000002, 100%, 32.8%)","tertiaryTextActiveColor":"hsl(201.10000000000002, 100%, 31.1%)","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"rgba(0, 114, 176, 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid rgba(0, 114, 176, 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px #0072B0, 0 0 0 4px rgba(0, 114, 176, 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-300)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px #0072B0, 0 0 0 4px rgba(0, 114, 176, 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.16)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.12)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-primary)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"500","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#0C5C8D","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#62C026","blogColor":"#730015","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#C20025","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#F3704B","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#EE4B5B","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#491B62","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#0072B0","secondary":"#333333","bodyText":"#222222","bodyBg":"#F5F5F5","info":"#1D9CD3","success":"#62C026","warning":"#FFD651","danger":"#C20025","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#C20025","#081B85","#009639","#B3C6D7","#7CC0EB","#F29A36","#B2D7EB","#66AFD7","#007ABC","#343434","#0E6EB9","#0072B0"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Neusa Next Pro Wide Bold","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"30px","h2FontSize":"25px","h3FontSize":"20px","h4FontSize":"18px","h5FontSize":"16px","h6FontSize":"16px","lineHeight":"1.1","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":null,"imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"14px","defaultMessageHeaderMarginBottom":"10px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"10px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"14px","specialMessageHeaderMarginBottom":"10px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"10px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Proxima Nova A Medium","fontStyleBase":"NORMAL","fontWeightBase":"500","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.2","fontSizeBase":"15px","fontSizeXxs":"11px","fontSizeXs":"12px","fontSizeSm":"13px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Proxima Nova A Medium","styles":[{"style":"NORMAL","weight":"500","__typename":"FontStyleData"}],"assetNames":["ProximaNovaAMedium-normal-500.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Neusa Next Pro Wide Bold","styles":[{"style":"NORMAL","weight":"700","__typename":"FontStyleData"}],"assetNames":["NeusaNextProWideBold-normal-700.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1751560860056","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:f5.prod:pages/kbs/TkbMessagePage:board:codeshare-1751560855926":{"__typename":"CachedAsset","id":"quilt:f5.prod:pages/kbs/TkbMessagePage:board:codeshare-1751560855926","value":{"id":"TkbMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":"transparent","showTitle":true,"showDescription":true,"textPosition":"CENTER","textColor":"var(--lia-bs-body-color)","sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"tkbs.widget.tkbArticleWidget","className":"lia-tkb-container","props":{"contributorListType":"panel","showHelpfulness":false,"showTimestamp":true,"showGuideNavigationSection":true,"showVersion":true,"lazyLoad":false,"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"featuredWidgets.widget.featuredContentWidget","className":null,"props":{"instanceId":"featuredWidgets.widget.featuredContentWidget-1702666556326","layoutProps":{"layout":"card","layoutOptions":{"useRepliesCount":false,"useAuthorRank":false,"useTimeToRead":true,"useKudosCount":false,"useViewCount":true,"usePreviewMedia":true,"useBody":false,"useCenteredCardContent":false,"useTags":true,"useTimestamp":false,"useBoardLink":true,"useAuthorLink":false,"useSolvedBadge":true}},"titleSrOnly":false,"showPager":true,"pageSize":3,"lazyLoad":true},"__typename":"QuiltComponent"},{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":true,"useTitle":true,"listVariant":{"type":"listGroup"},"pageSize":3,"style":"list","pagerVariant":{"type":"loadMore"},"viewVariant":{"type":"inline","props":{"useRepliesCount":true,"useMedia":true,"useAuthorRank":false,"useNode":true,"useTimeToRead":true,"useSpoilerFreeBody":true,"useKudosCount":true,"useNodeLink":true,"useViewCount":true,"usePreviewMedia":false,"useBody":false,"timeStampType":"postTime","useTags":true,"clampSubjectLines":2,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useTextBody":true,"useSolvedBadge":true,"useAvatar":true,"useAuthorLogin":true,"useUnreadCount":true}},"lazyLoad":true,"panelType":"divider"},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1751560860056","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/kbs/TkbMessagePage-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-pages/kbs/TkbMessagePage-1751560860056","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This article cannot be found","name":"TKB Message Page","section.message-list.title":"","archivedMessageTitle":"This Content Has Been Archived","section.erPqcf.title":"","section.erPqcf.description":"","section.message-list.description":""},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1751560860056","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:quiltWrapper:f5.prod:Common:1751560857109":{"__typename":"CachedAsset","id":"quiltWrapper:f5.prod:Common:1751560857109","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#343434","items":[{"id":"custom.widget.GainsightShared","props":{"widgetVisibility":"signedInOnly","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Beta_MetaNav","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"700","controllerHighlightColor":"#F29A36","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":1,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"48px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"unset","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-white)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-dark)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"var(--lia-bs-body-color)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-white)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid var(--lia-bs-white)","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-white)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-white)"},"links":{"sideLinks":[],"logoLinks":[],"mainLinks":[{"children":[{"linkType":"INTERNAL","id":"migrated-link-1","params":{"boardId":"TechnicalForum","categoryId":"Forums"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-2","params":{"boardId":"WaterCooler","categoryId":"Forums"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-0","params":{"categoryId":"Forums"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-4","params":{"boardId":"codeshare","categoryId":"CrowdSRC"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-5","params":{"boardId":"communityarticles","categoryId":"CrowdSRC"},"routeName":"TkbBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-3","params":{"categoryId":"CrowdSRC"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-7","params":{"boardId":"TechnicalArticles","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"article-series","params":{"boardId":"article-series","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"security-insights","params":{"boardId":"security-insights","categoryId":"Articles"},"routeName":"TkbBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-8","params":{"boardId":"DevCentralNews","categoryId":"Articles"},"routeName":"TkbBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-6","params":{"categoryId":"Articles"},"routeName":"CategoryPage"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-10","params":{"categoryId":"CommunityGroups"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"migrated-link-11","params":{"categoryId":"F5-Groups"},"routeName":"CategoryPage"}],"linkType":"INTERNAL","id":"migrated-link-9","params":{"categoryId":"GroupsCategory"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-12","params":{"boardId":"Events","categoryId":"top"},"routeName":"EventBoardPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-13","params":{"boardId":"Suggestions","categoryId":"top"},"routeName":"IdeaBoardPage"},{"children":[],"linkType":"EXTERNAL","id":"Common-external-link","url":"https://community.f5.com/c/how-do-i","target":"SELF"}]},"className":"QuiltComponent_lia-component-edit-mode__lQ9Z6","showSearchIcon":false,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"#343434","visualEffects":{"showBottomBorder":false},"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-white)"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"#343434","linkHighlightColor":"#FFFFFF","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"linkTextColor":"#FFFFFF"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-body-color)","items":[{"id":"custom.widget.Beta_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Tag_Manager_Helper","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"custom.widget.Consent_Blackbar","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:component:custom.widget.GainsightShared-en-us-1751560900627":{"__typename":"CachedAsset","id":"component:custom.widget.GainsightShared-en-us-1751560900627","value":{"component":{"id":"custom.widget.GainsightShared","template":{"id":"GainsightShared","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Shared functions for Gainsight integration","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GainsightShared","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Shared functions for Gainsight integration","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Beta_MetaNav-en-us-1751560900627":{"__typename":"CachedAsset","id":"component:custom.widget.Beta_MetaNav-en-us-1751560900627","value":{"component":{"id":"custom.widget.Beta_MetaNav","template":{"id":"Beta_MetaNav","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"MetaNav menu at the top of every page.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Beta_MetaNav","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"MetaNav menu at the top of every page.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Beta_Footer-en-us-1751560900627":{"__typename":"CachedAsset","id":"component:custom.widget.Beta_Footer-en-us-1751560900627","value":{"component":{"id":"custom.widget.Beta_Footer","template":{"id":"Beta_Footer","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"DevCentral´s custom footer.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Beta_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"DevCentral´s custom footer.","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Tag_Manager_Helper-en-us-1751560900627":{"__typename":"CachedAsset","id":"component:custom.widget.Tag_Manager_Helper-en-us-1751560900627","value":{"component":{"id":"custom.widget.Tag_Manager_Helper","template":{"id":"Tag_Manager_Helper","markupLanguage":"HANDLEBARS","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Helper widget to inject Tag Manager scripts into head element","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Tag_Manager_Helper","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Helper widget to inject Tag Manager scripts into head element","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.Consent_Blackbar-en-us-1751560900627":{"__typename":"CachedAsset","id":"component:custom.widget.Consent_Blackbar-en-us-1751560900627","value":{"component":{"id":"custom.widget.Consent_Blackbar","template":{"id":"Consent_Blackbar","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Consent_Blackbar","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1751560860056","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1751560860056","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/tkbs/TkbArticleWidget-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/tkbs/TkbArticleWidget-1751560860056","value":{},"localOverride":false},"Category:category:Forums":{"__typename":"Category","id":"category:Forums","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:TechnicalForum":{"__typename":"Forum","id":"board:TechnicalForum","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:WaterCooler":{"__typename":"Forum","id":"board:WaterCooler","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:Articles":{"__typename":"Category","id":"category:Articles","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:TechnicalArticles":{"__typename":"Tkb","id":"board:TechnicalArticles","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:DevCentralNews":{"__typename":"Tkb","id":"board:DevCentralNews","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:GroupsCategory":{"__typename":"Category","id":"category:GroupsCategory","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:F5-Groups":{"__typename":"Category","id":"category:F5-Groups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:CommunityGroups":{"__typename":"Category","id":"category:CommunityGroups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Occasion:board:Events":{"__typename":"Occasion","id":"board:Events","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"occasionPolicies":{"__typename":"OccasionPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Idea:board:Suggestions":{"__typename":"Idea","id":"board:Suggestions","boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"ideaPolicies":{"__typename":"IdeaPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:communityarticles":{"__typename":"Tkb","id":"board:communityarticles","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:security-insights":{"__typename":"Tkb","id":"board:security-insights","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Tkb:board:article-series":{"__typename":"Tkb","id":"board:article-series","tkbPolicies":{"__typename":"TkbPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"CachedAsset:text:en_US-components/community/Navbar-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1751560860056","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","migrated-link-9":"Groups","migrated-link-7":"Technical Articles","migrated-link-8":"DevCentral News","migrated-link-1":"Technical Forum","migrated-link-10":"Community Groups","migrated-link-2":"Water Cooler","migrated-link-11":"F5 Groups","Common-external-link":"How Do I...?","migrated-link-0":"Forums","article-series":"Article Series","migrated-link-5":"Community Articles","migrated-link-6":"Articles","security-insights":"Security Insights","migrated-link-3":"CrowdSRC","migrated-link-4":"CodeShare","migrated-link-12":"Events","migrated-link-13":"Suggestions"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1751560860056","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1751560860056","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1751560860056","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1751560860056","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1751560860056","value":{"place":"Place {name}"},"localOverride":false},"QueryVariables:TopicReplyList:message:278096:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:278096:1","value":{"id":"message:278096","first":10,"sorts":{"postTime":{"direction":"ASC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":false,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1751560860056","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1751560860056","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1751560860056","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solution","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1751560860056","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1751560860056","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1751560860056","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1751560860056","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1751560860056","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageRevision-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageRevision-1751560860056","value":{"lastUpdatedDatePublished":"{publishCount, plural, one{Published} other{Updated}} {date}","lastUpdatedDateDraft":"Created {date}","version":"Version {major}.{minor}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1751560860056","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageAuthorBio-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageAuthorBio-1751560860056","value":{"sendMessage":"Send Message","actionMessage":"Follow this blog board to get notified when there's new activity","coAuthor":"CO-PUBLISHER","contributor":"CONTRIBUTOR","userProfile":"View Profile","iconlink":"Go to {name} {type}"},"localOverride":false},"CachedAsset:text:en_US-components/guides/GuideBottomNavigation-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/guides/GuideBottomNavigation-1751560860056","value":{"nav.label":"Previous/Next Page","nav.previous":"Previous","nav.next":"Next"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1751560860056","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1751560860056","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1751560860056","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1751560860056","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserRegistrationDate-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserRegistrationDate-1751560860056","value":{"noPrefix":"{date}","withPrefix":"Joined {date}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1751560860056","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1751560860056":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1751560860056","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false}}}},"page":"/kbs/TkbMessagePage/TkbMessagePage","query":{"boardId":"codeshare","messageSubject":"powershell-management-folder","messageId":"278096"},"buildId":"3XH0qYWYCnEYycuN5W4S8","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"f5","serviceVersion":"25.4.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_customComponent_CustomComponent","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_tkbs_TkbArticleWidget","components_messages_MessageView_MessageViewStandard","components_messages_ThreadedReplyList","components_customComponent_CustomComponentContent_TemplateContent","components_customComponent_CustomComponentContent_HtmlContent","shared_client_components_common_List_UnwrappedList","components_tags_TagView","components_tags_TagView_TagViewChip","components_customComponent_CustomComponentContent_CustomComponentScripts"],"appGip":true,"scriptLoader":[]}
/discussions/technicalforum/connection-limit-on-vs-and-redirect-page/122022
