cjunior
Nacreous
Nacreous
Problem this snippet solves:
This iApp provides a network map with BIG-IP objects and its dependencies. I want with this solution, to get a view of the branched objects becoming more apparent where and how they are linked together. It can be a little slow and costly while creating a more complex net map by using php as the engine to requests in the local iControlREST. For the HTML, it uses the vis.js (http://visjs.org/) and jQuery libraries to create the web map view.
It might be better and make more sence to host this implementation outside the BIG-IP, but for this, I created the iApp to publish it as example.
How to use this snippet:
Code :
67191
Tested this on version:
11.5
Version history
Last update:
‎03-Mar-2016 13:18
Updated by:
Contributors
