The_Bhattman
Altostratus
Altostratus
Problem this snippet solves:
The following is an example how powerful the LTM in terms of hosting web pages w/o the necessity of having a physical web server. This technique can sometimes save you from purchasing or taking up valuable resource on a production web server for hosting a webpage.
This particular iRule throws up a network calculator which was coded by Al Vonkeman (http://www.subnetmask.info./)).
NOTE: The website does initially load up slowly. Thereafter it performs quickly as the processing is client side.
Code :
if {[HTTP::uri] eq "/calc" } {
set response {
Network Calculators
< SCRIPT type="text/javascript">
Network Calculators
Subnet Mask Calculator
   < script type="text/javascript"></script>
Enter the TCPIP Network Address:
Force as Class: Default Class A Class B Class C
Enter the required number of sub-networks:
OR enter the required number of nodes/hosts per network (including network & broadcast addresses)***:
Network Class:
Subnet Mask: or
Subnets:
Nodes/Hosts per Network (including network and broadcast addresses)***:
Network/Node Calculator
Enter the Subnet Mask:
Enter the TCPIP Address:
Network:
Node/Host:
Broadcast Address:
IP Address Converter
Enter the dotted decimal TCPIP Address:
or Enter the binary TCPIP Address:
or Enter the hex TCPIP Address:
or Enter the decimal TCPIP Address:
Subnet Mask Converter
Enter the dotted decimal Subnet Mask
or Enter the number of bits in the subnetmask /
Subnet Mask Inverter
Enter inverted Subnet Mask
< SCRIPT type="text/javascript"> } HTTP::respond 200 content $response "Content-Type" "text/html" } }
Comments
Joe_M
This doesn't work properly on 11.5.3. I haven't tested anything else. The Subnet calculator here: http://jodies.de/ipcalc works much better for my needs. If that could be converted into an iRule that would be fantastic!
Version history
Last update:
‎18-Mar-2015 13:02
Updated by:
Contributors
