Kai_Wilke
MVP
MVP
Problem this snippet solves:
The outlined iRule can be used to access independent LDAP(S) instances behind a single Virtual Server using a single Base-DN.
The iRule, will forward LDAP(S) requests to an additional LDAP(S) pool, if the Simple-Bind user account name matches the $static::other_domains list.
The iRule would then translate the original Base-DN to the Base-DN matching the additional LDAP(S) instance.
Note1: The iRule doesn't adjust ASN.1/BER structures. So the original and changed Base-DN MUST have the same length. You may have to add SPACE paddings to allign the lenght of the Base-DNs.
Note2: The iRule wouldn't change the traffic for the default LDAP(S) instance. The traffic is passed through after the Simple-Bind request is completed.
Note3: The iRule would translates just the LDAP requests destined to the Base-DN of the additional LDAP(S) instance. The retrived results could then be accessed using their original DNs.
Cheers, Kai
How to use this snippet:
  • Setup a standard Virtual Server for TCP:636.
  • Apply SNAT and TCP profiles as needed.
  • Apply client and server side SSL profiles. The server side SSL profile has to support both instances.
  • Assign the default LDAP(S) instance as default_pool.
  • Tweak the RULE_INIT event to match your environment.
Code :
when RULE_INIT {
# Minimalistic LDAP(S) proxy (via Simple-Bind) with Base-DN rewrite
# Configuration of the other LDAP(S) instance username prefix/suffixes
set static::other_domains [list "itacs\\" "@itacs.de"];# List of lower case domain strings
# Configuration of the other LDAP(S) instance pool name
set static::other_ldaps_poolname OTHER_LDAPS_POOL_NAME;# Value of the other pool name
# Configuration of the Base-DN translation strings
# Important: The Base-DNs MUST have the same lenght.
#            You have to pad SPACES to match the length
binary scan "OU=xyz,DC=your-domain,DC=tld" H* temp(dn_default) ;# This is the default Base-DN
binary scan "OU=f5-team, DC=itacs,  DC=de" H* temp(dn_other);# This is the other Base-DN. Pad SPACES to match the length
set static::other_base_dn_map [list $temp(dn_default) $temp(dn_other)]
unset -nocomplain temp
when CLIENTSSL_HANDSHAKE {
# SSL session init
set session_binding_ldap 1
set session_other_active 0
# Collecting SSL data
SSL::collect
when CLIENTSSL_DATA {
if { $session_binding_ldap } then {
# Searching for simple Bind request to the other LDAP(S) instance
set session_binding_ldap 0
foreach temp(domain_string) $static::other_domains {
if { [string tolower [SSL::payload]] contains $temp(domain_string) } then {
# Forwarding the request to the other LDAP(S) instance
set session_other_active 1
pool $static::other_ldaps_poolname
log -noname local0.debug "Bind request for other LDAP(S) instance detected. Forwarding the connection to pool [LB::server pool]"
break
if { $session_other_active == 0 } then {
# Forwarding the request to the default LDAP(S) instance
log -noname local0.debug "LDAPS request for default LDAP(S) instance detected. Forwarding the connection to pool [LB::server pool]"
# Releasing SSL data
SSL::release
if { $session_other_active } then {
# Translating Base-DNs for the other LDAP(S) instance
binary scan [SSL::payload] H* temp(hex_ssl_payload)
set temp(new_ssl_payload) [binary format H* [string map $static::other_base_dn_map $temp(hex_ssl_payload)]]
SSL::payload replace 0 [string length [SSL::payload]] $temp(new_ssl_payload)
SSL::release
# Collecting further SSL data
SSL::collect
Tested this on version:
12.0
Version history
Last update:
‎25-Jan-2016 03:43
Updated by:
Contributors
