Problem this snippet solves:
This example java class allows access to the JSSE Trust Layer allowing access to self-signed server certificates for HTTPS based SOAP connections.
Code :
 * The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
 * Software Development Kit for iControl"; you may not use this file except in
 * compliance with the License. The License is included in the iControl
 * Software Development Kit.
 * Software distributed under the License is distributed on an "AS IS"
 * basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
 * the License for the specific language governing rights and limitations
 * under the License.
 * The Original Code is iControl Code and related documentation
 * distributed by F5.
 * The Initial Developer of the code is Jacob Gilley.
 * Portions created by F5 are Copyright (C) 1996-2004 F5 Networks
 * Inc. All Rights Reserved.  iControl (TM) is a registered trademark of
 * F5 Networks, Inc.
 * Alternatively, the contents of this file may be used under the terms
 * of the GNU General Public License (the "GPL"), in which case the
 * provisions of GPL are applicable instead of those above.  If you wish
 * to allow use of your version of this file only under the terms of the
 * GPL and not to allow others to use your version of this file under the
 * License, indicate your decision by deleting the provisions above and
 * replace them with the notice and other provisions required by the GPL.
 * If you do not delete the provisions above, a recipient may use your
 * version of this file under either the License or the GPL.
import java.security.AccessController;
import java.security.InvalidAlgorithmParameterException;
import java.security.KeyStore;
import java.security.KeyStoreException;
import java.security.PrivilegedAction;
import java.security.Security;
import java.security.cert.X509Certificate;
import javax.net.ssl.ManagerFactoryParameters;
import javax.net.ssl.TrustManager;
import javax.net.ssl.TrustManagerFactorySpi;
import javax.net.ssl.X509TrustManager;
public final class XTrustProvider extends java.security.Provider
  private final static String NAME = "XTrustJSSE";
  private final static String INFO =
    "XTrust JSSE Provider (implements trust factory with truststore validation disabled)";
  private final static double VERSION = 1.0D;
  public XTrustProvider()
    super(NAME, VERSION, INFO);
    AccessController.doPrivileged(
      new PrivilegedAction()
        public Object run()
          put("TrustManagerFactory." + TrustManagerFactoryImpl.getAlgorithm(),
            TrustManagerFactoryImpl.class.getName());
          return null;
  public static void install()
    if(Security.getProvider(NAME) == null)
      Security.insertProviderAt(new XTrustProvider(), 2);
      Security.setProperty("ssl.TrustManagerFactory.algorithm",
        TrustManagerFactoryImpl.getAlgorithm());
  public final static class TrustManagerFactoryImpl extends TrustManagerFactorySpi
    public TrustManagerFactoryImpl() { }
    public static String getAlgorithm() { return "XTrust509"; }
    protected void engineInit(KeyStore keystore) throws KeyStoreException { }
    protected void engineInit(ManagerFactoryParameters mgrparams)
      throws InvalidAlgorithmParameterException
      throw new InvalidAlgorithmParameterException(XTrustProvider.NAME +
        " does not use ManagerFactoryParameters");
    protected TrustManager[] engineGetTrustManagers()
      return new TrustManager[]
        new X509TrustManager()
          public X509Certificate[] getAcceptedIssuers() { return null; }
          public void checkClientTrusted(X509Certificate[] certs, String authType) { }
          public void checkServerTrusted(X509Certificate[] certs, String authType) { }
Comments
fgb_29511
Can you explain how to use this code with iControl ??
fgb_29511
ok, I've found samples in SDK. But it doesn't work. To solve my issue, I replaced temporarily the axis jar by an old version. But that's odd...
Version history
Last update:
‎07-Mar-2015 16:05
Updated by:
Contributors
