Gregory_Robinso
F5 Employee
F5 Employee
Problem this snippet solves:
Here's a simple script that shows token authentication working.
How to use this snippet:
Replace the "test" and "api" variables with your username and password. Set the BIG-IP management IP variable in target_bigip.
Code :
#!/usr/bin/env python3
import json,requests
requests.packages.urllib3.disable_warnings()
target_bigip = '10.1.1.134'
def tokenauth(username,password):
  apiCall = requests.session()
  apiPayload = {}
  apiHeaders = {}
  apiPayload['username'] = username
  apiPayload['password'] = password
  apiPayload['loginProviderName'] = 'tmos'
  apiHeaders['Content-type'] = 'application/json'
  apiUrl = 'https://' + target_bigip + '/mgmt/shared/authn/login'
  apiResponse = apiCall.post(apiUrl,data=json.dumps(apiPayload),verify=False,headers=apiHeaders)
  apiResponseJson = json.loads(str(apiResponse.text))
  return(apiResponseJson['token']['token'])
def restput(token,path,payload):
  apiCall.auth = None
  apiHeaders = {}
  apiHeaders['X-F5-Auth-Token'] = token
  apiUrl = 'https://' + target_bigip + path
  apiResponse = apiCall.put(apiUrl,headers=apiHeaders,data=json.dumps(payload),verify=False)
  return(apiResponse.text)
if __name__ == "__main__":
  # Perform token authentication
  print('Grabbing auth token')
  mytoken = tokenauth('rest','api')
  print(mytoken)
  # Make an API call using the token
  print('Making the API call')
  mycall = restput(mytoken,'/mgmt/tm/sys/ssh',{"banner-text":"UPDATED!"})
  print('API response: ' + mycall)
  quit()
Tested this on version:
12.0
Version history
Last update:
‎13-Aug-2019 05:57
Updated by:
Contributors
